Results 1 to 7 of 7
    Oct 2009
    the problem is pag ngstart ko ung kotse (honda ESI) minsan ayaw mawala ung color yellow (ung me engine pix) hirap istart. pnu po p un?? nu kya possible na sira nun/ tnx.
    [SIZE="4"]REMINDER: do not post message in SMS/TXT format in the tsikot.com forums.
    READ the RULES.
    [/SIZE]
    Quote Originally Posted by bozjamez View Post
    The yellow light is the CHECK ENGINE light. It means either a sensor or the engine's ECU is faulty. Beyond that, you'll need a shop with a computer-analyzer to pinpoint the actual problem.
    Sep 2004
    Your car is telling you there is something wrong with it. Have it diagnosed. My friend just replaced the ECU in his civic esi which I used to own.
    Sep 2009
    bro,
    ganyan din ang problem ko dati sa ESI ko, ask ko lang kung lahat ba ng sensor mo gumagana pati odomoeter mo? kasi sa akin sira lang yung odometer ko i replaced it then nawala na yung check engine light. pero mas maganda nga have it check yung ECU
    Feb 2009
    baka main relay..
    try mo palitan yung main relay/ecu relay.ganyan din naging prob ng esi ko.pinalitan ko ng main relay.yun.ok na.
HELP nmn ung ayaw mgstart ng HONDA ESi ko
