Results 1 to 7 of 7
    Oct 2009
    mga kuya ask lang po ma fifeel niyo ba ang difference ng takbo kng nag kabit ka ng turbo sa ph12 (stock engine) ng hatchback? sisipa ba? :D
    may binebenta kasi saking obx turbo kit for ph12,d15b,ph16 compatible daw...
    ok ba yun mejo ala kasi budget for d15b pa sa ngaoyn
    malaki ba diference ng d15b vtec sa d15b vtec n naka turbo?
    tska ask ko n rin po magkano price ng d15b vtec ngayon , may gumagawa ba sa banawe san po magaling if ever :D
    sorry noob question baguhan lng po
    TIA...
    Last edited by r1_kcirevam; October 10th, 2009 at 02:52 AM. Reason: additional info
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT format.
    READ the RULES.
    [/SIZE]
    Apr 2009
    Quote Originally Posted by r1_kcirevam View Post
    Try inquiring sa Forcedspeed. I recall in one TOYS FOR D BOYS mag issue na may ginawa silang ganyan. Pero by theory I think wala masyadong gains and worst, baka mastress ng husto ang internals mo since the boring in the chamber is too little/not strong enough to tolerate such high induced pressure from the turbo.. remember 1200cc lang yan, carb pa...
    Magkano daw? Baka naman mas mahal pa kesa magpatransplant ka ng ph16, d15b or d16a...Papost naman dito kung magkano daw, hehe.. at kung ano yung mga kasama sa kit? May intercooler na ba?
    Naka-d15b N.A. ako and have not yet seen/ridden on one that runs on turbo, pero based on entries sa forums ng JDM d15b tuners here and abroad, sabi nila malakas daw yun but relatively lang siguro... not strong enough to outrun an NA b16a, sabayan siguro kaya ... Well, depende din sa pagkakagawa. Gagastusan mo ng husto yan. Put in a jdm d15b first (yung efi, wag yung dual carb) tsaka mo na po ito problemahin...
    d15b yata nasa around 45k up. Not sure kung ano yung mga accessories na kasama nun. Try mo sa hongly alam ko sanay sila sa mga honda engine transplants...
    Engines with high compression ratio pistons do not take to turbocharging well. At best, it would be limited to about 6 to 8 psi boost. Any higher would lead to engine damage.
    Unless you change to forged internals or lower the engine's compression to take higher boost levels.
    I'd go for supercharging VTEC's but it's quite expensive here.
    Quote Originally Posted by ssaloon View Post
    I would still go for turbocharging because supercharging is not that efficient and usually limited in output. Just a matter of balancing the size of the compressor vs the turbine for best performance.
    But you still can't beat the feel of a properly setup all-motor car.
    Oct 2009
    dudes kuya is this engine a d15b vtec efi? ok ba to malakas ba?
help  hatchback turbo , d15b inquiries lang po
