Results 1 to 5 of 5
- May 2010
- 5
May 10th, 2010 07:51 PM #1ano po ba problema kpag mababa na yung gas ko eh ang hirap start s unang crank tapos sa second crank dun lang sumisindi yung engine? pag lagpas po sa gitna ng line or puno yung gas tank ko ang bilis mag start ng makina..HELP! ung car ko po is a 1998 honda civic vtec A/T. Yun lang ang napansin ko kapag low on fuel na ako at mababa na sa gitna sa unang crank ayaw nya sumindi pero after ko na magamit all day or once na na start ko na sya ok naman..yun lang kapag low on fuel na sya nagkakaproblema.
May 10th, 2010 08:05 PM #2
try to check the fuel line and fuel pump. baka hindi na gaano makahigop ng gas kung less than half na.
May 10th, 2010 09:03 PM #3
fuel pump mo mukhang bumibigay na, try checking ur fuel filter also (baka barado na kasi ur playing with empty, yung crud sa lower part ng fuel tank mo baka hinihigop rin);
- May 2010
- 5
May 10th, 2010 11:39 PM #4salamat sa mga reply nyo..ano po ba yung dapat ko i-check kasi sabi saken madami daw cause yan either yung fuel pump, igniton coil at high tension wire..ano po ba ang first step ko at unahing tignan? thanks!
May 10th, 2010 11:49 PM #5
theres no way ignition coil or high tension wire prob niya kasi kung marami ka gas, no prob sa pagstart. its not a electrical prob.
try looking at the fuel system first, fuel pump, filter, lines. malamang nandiyan yung prob. baka mahina na pressure na binibigay ng fuel pump.
