Results 1 to 13 of 13
    Apr 2012
    Help mga boss..1 lakaran lng ubos agad tubig..pero di naman nag over heat.normal half temp din sa guage..nu kaya prob?parang malakas din ang tagas ng tubig pagdating sa bahay or office (ac on during travel)
    Nov 2007
    Quote Originally Posted by Oikim View Post
    I'm pretty sure there is a leaking hose somewhere in your system, check also your vehicle's thermostat.
    Apr 2011
    inspect closely for leaks. Replace your radiator cap as well.
    Jan 2011
    Daming pwedeng maging sira niyan. Baka first sign ng blown head gasket. Check mo ding yung water pump, baka may tagas doon because of small rock punctures.
    Did your engine overheat even for a short time before? It might be possible the engine head could have warped slightly and the water is ending up in the cylinders.
    try using a coolant bro. that way it would be easier to spot for leaks because it will leave stains stemming from the evaporation of your coolant.
    Apr 2012
    No overheat kahit once.around 30kms daily.still normal temp.always refilling water every morning nga lng.havent tried non ac kung malakas or meron pa rin ba ang tagas.
    Jan 2011
    Tingnan mo kung puno ang reservoir right after ng driving. Most likely, doon ang punta ng tubig tapos di bumabalik sa radiator.
    Apr 2012
    Opo.yung reservoir ang laging ubos.ok naman ang tubig sa radiator.
    meron leak yan, pag mainit na ang makina try to open ang hood at tignan baka meron pin hole kaya di masyadong pansinin, tignan mo kung saan nagbabasa, or tignan mo ang radiator fins baka basa or ang water pump meron weep hole ito baka doon lumalabas ang H2O.
    overhaul ng radiator and replace the radiator cap.
    Check mo kung may tulo doon sa parking nyo pag-gising sa umaga. Tapos warm up mo yong engine hanggang normal level, turn off yong makina at check after mga 15 minutes kung may tulo. Pero the easiest it to bring to rediator specialist.
    Dec 2007
    bring it to honda spa sa may mindanao avenue meron sila pang leak test ng cooling system para makita kung saan nangagaling.
Help:ang bilis maubos tubig ng radiator.vti 96
