Results 1 to 8 of 8
- Apr 2009
- 10
August 17th, 2011 05:45 PM #1Mga Guro's Tulong naman po, anong cause kaya nito when i make a turn tumutunog ang rear diff ko. very annoying sound parang gears na nag memetal to metal contak parang GRRRRRRRRRRRRRR! ang tunog. 2 times ko na dinala sa casa what they did was lift the car drained the differential fluid linigyan ng Gasolina pina andar habang naka lift stepped on the gas until it reaches 80-100km/hr sa spedo drain the gasoline lagyan ulit fluid apak ulit gas for a few seconds then drain ulit and fluid and refill ulit fluid. Nawawala ang parang grinding sound pero after a few months balik na naman ulit. Anybody na naka experience ng ganito? Low milage CRV almost 6 yrs na 43k palang odo. Help naman mga braders TIA!
- Nov 2008
- 148
August 19th, 2011 10:30 PM #2It seems that you need to consider an overhaul of your rear differential.
- Sep 2005
- 141
August 20th, 2011 01:18 PM #3Have you tried changing diff oil to DPSF? This is the recommended oil for our V's differential.
August 20th, 2011 03:23 PM #4
parang bumigay na rear diff.
2 choices na lang:
tangalin yung rear diff and make it 4x2 or palitan na lang outright yung rear diff. common problem talaga po yan sa crv.
- Apr 2009
- 10
August 22nd, 2011 05:03 PM #5
- Jul 2011
- 58
August 22nd, 2011 07:07 PM #6this happened to me before sa 1st gen V ko, i brought it to honda SPA tandang sora,ganyan din ginawa, drain ng rear diff fluid, then ok na, 2 yrs na at walang prob since then
Tsikot Member Rank 4
- Jan 2007
- 2,326
August 23rd, 2011 03:31 AM #7Input lang din po. It happened to my CUV na din. They had to have the bearings machine shopped then replaced the gear oil. Pero kasali din yata ako sa nagkamali. Matagal na kasi akong naka FWD na walang diff -- to the point na nalimutan ko na dapat iniinspect at periodically nire replace ang gear oil lalo kung nasabak sa baha. Dahil maaaring nako contaminate ito kahit di kataasan ang tubig. HTH.
- Mar 2013
- 2
March 27th, 2013 01:17 AM #8patulong naman po. saan po kaya pwede makabili ng dpsf 2 na 1liter lang. konti lang kasi kulang pero 4L available sa casa.
Latest mileage:
