Originally Posted by
restituto
My City 2003 has two radiator fans. The 2nd radiator fan on the left side (driver side) sometimes would not function. This result to inefficient aircon cooling on the cabin. Would normally the 2nd radiator fan should work when the aircon compressor kicks in? I only knew the problem when I ask a friend mechanic why the aircon is not cooling well. He checked the cooling fan while the aircon is on and we found that the other fan is not working....might be stucked up or whatever. He tried to tap lightly with a small hammer the cooling fan frame/assembly and the fan started to work. In this regard, may I ask your advice or opinion if there's really a need to replace the cooling fan assembly or it just needs cleaning or maybe there are other defects that contributed to its malfunctioning.
By the way, I also noticed one time that the said fan is rotating but at slower speed. If the fan motor needs to be replaced or relay, magkano kaya ang price nito sa casa and outside parts dealer? Thank you for any info you can share. Regards to all.
