Results 1 to 9 of 9
    Oct 2019
    Radiator leaking when car is not using for days. if on engine no leaks
    please help me what is the possible solution for this?
    the circle on picture (near the petcock) has water leak when the car is not using for days. the water from the reservoir tank is draining.
    but if i use the car. it doesnt loose any water. even long drive.
    salamat ng marami!!
    thank you!
    the car is honda civic ESI 92-95 model75534884_950544615311119_6672065607950663680_n.jpg
    Jan 2008
    Replace mo yung o-ring nung drain plug. Walang leak when its hot due to the rubber expanding sealing the leak
    Oct 2019
    saan kaya makakabili nun sir? may code ba un? or model? salamat sa reply sir
    Quote Originally Posted by NewbieLang View Post
    Raplace the whole drain plug, not the o-ring only. Madami sa auto supply, just bring the sample, 30-50 pesos lang bili namin dati (that's for an Adventure).
    Oct 2019
    Quote Originally Posted by jvnj View Post
    oo nga po sir eh. kaso mahirap na raw po drain plug nito po. if ever baka O-ring po meron.
    Ginawa ko nung nasira O-ring nung Hilander namin at hindi ako makahanp ng kapalit, nilagyan ko ng teflon tape. Problem solved.
