Results 1 to 7 of 7
    Dec 2008
    I have a 97 Civic Lxi and it's dark-tinted. I'm currently using 145x100 headlamps. I opted to try and install Xenonworx HID lamps, but I preferred not to since I found solid lighting from the regular hallogen lamps.
    Only thing is I want to try higher wattage like 170x130 / 170x100, but I'm not sure if it's possible since Civic uses plastic headlamp covers. It might get burned.
    Any advise?
    Aug 2005
    Replace your "maniac" tints with the lightest tints available.
    Peace.
    Dec 2008
    Peace.
    Well, thanks for your share of thought. I appreciate that.
    But FYI, dark tint is far different from black tint - it's what you called "maniac."
    Peace.
    wow! the wattage you want is way high. hehe
    try replacing the sockets to ceramic ones and add a relays... thats your best bet.
    Dec 2008
    Quote Originally Posted by archie123456789 View Post
    you must be right, it is way too high. guess i'll have to settle with 145 instead.
    Aug 2005
    There is a good thead on the topic.
    http://tsikot.yehey.com/forums/showt...55#post1171855
    IMO i would consider and check first if my lens and reflectors are clean before doing an upgrades. try to re-aim the beam correctly to lessen the cost due to numerous upgrades/replacements....and hope nobody gets annoyed by too much glare created. good luck
Advisable Headlamps' Wattage for 97 Civic
