Results 1 to 2 of 2
- Oct 2010
- 6
October 31st, 2010 08:58 PM #1Hi,
Need help on my honda 94 esi brake fluid leak.
Pina-check ko na sa shop, they already check all lining on both rear tires and front tires. Isa lang ginawa nila, pinalitan nila yung goma sa isa sa rear tire. But eventually, same problem occurs. The leak is not that gradual, you will only noticed it for like 1 week... kasi the break fluid indicator will light up.
The only workaround na ginagawa ko ngayon is lagi akong may baon na break fluid... which is I'm not comfortable... kasi bigla na lang akong mawalan ng preno.
Please advised.
My location is here in San Pedro, Laguna. Kindly advise on where in San Pedro or nearby like Santa Rosa or Binan na matinong shop.
Thanks in advance.
November 1st, 2010 02:34 PM #2
brod sa may sta rosa may magaling na mechaniko from Honda Sta Rosa Plant...
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
