Results 1 to 9 of 9
- Feb 2007
- 60
April 28th, 2011 10:43 PM #1Mga Sir, seeking for your inputs once again... My car is 96 VTI stock PH16A engine
I am experiencing intermittent erratic idling when caught in traffic. Tumataas up to 2K rpm. As far as I have observed, it happens when AC is on. Pag pinatay ko kasi AC bumabalik sa normal. Pag wala masaydong traffic parang hindi lumalabas ang problem. Ano kaya cause neto?
Looking forward for your valuable inputs.
Thanks.
April 28th, 2011 10:48 PM #2
happened to me once on my civic. check mo vacuum hoses mo, it might be a leak.
- Feb 2007
- 60
- Feb 2007
- 60
April 29th, 2011 09:47 AM #6
- Apr 2011
- 7
April 29th, 2011 10:42 AM #7bos check mu un idle air valve control
try mumuna linisin ng carb cleaaner pag ganun pa din sira na yan
April 29th, 2011 05:45 PM #8
TS ikaw yung may erratic idling before din diba? yung nagdadrop rpm? i thought ok na problem? pinalinis mo IACV and Throttle body diba?
- Feb 2007
- 60
April 29th, 2011 06:38 PM #9yung dati sir parang suppressed ang takbo sa 2nd and 3rd gear pag bumitaw ako sa accelerator. Ngayon naman tumataas ang idling pag traffic with AC on.
Aside from IACV and TB cleaning, na-check ko na rin po ang TPS and ok naman ang reading. Check ko na rin vacuum hose. I'm thinking na baka sira na IACV ko like what hondacrv1889 said.
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
