Results 1 to 8 of 8
- Jan 2010
- 8
January 25th, 2010 08:10 AM #1sir any idea anu pwede ko gawin pa kasi ayaw mawala ng overheating ng accord ko. napalitan ko na ng gasket at napareface na head kaso malakas parin ang pressure.help lang or baka may marecomend na autoshop to solve my problem. ty:
January 25th, 2010 09:08 AM #2
napaayos mo naba ang rad, check rad fan, check thermostat ,and water pump? check narin belt. ano ano na ba ang napagawa mo?
- Jan 2010
- 8
January 25th, 2010 01:15 PM #3overhauled na yung radiator at naparefaced na ang cylinder head at change head gasket narin. ok naman ang fan pero yung ect nya ay nakarekta na at walang thermostat sa loob eh.tnx bro.
January 25th, 2010 04:46 PM #4
check mo na din iyong temperature sending unit. baka kailangan na palitan bro
January 25th, 2010 05:02 PM #5
- Jan 2010
- 8
January 26th, 2010 02:34 AM #6tnx sa mga idea.chek ko narin e kaso may overheating parin kasi pag pinisil ko yung hose may pressure sya.nag start sya magka pressure kapag over 2000rpm na ang andar ko.help pls
January 27th, 2010 09:02 AM #7
Uh... the hose is supposed to have pressure once the coolant is up to operating temperature.
How high is the pressure? Have you replaced the radiator cap yet?
- Jan 2010
- 8
January 27th, 2010 12:54 PM #8sobrang tigas ng hose pag may pressure na at tumatakas na yung tubig sa reservoir.
Yes, because 100 degrees boiling point is measured at sea level. What's interesting also is that...
