Results 1 to 12 of 12
    i just would like to ask the common source of that noise being heard coming from the engine its like a friction ( of course theres a friction inside) but its annoying at first i thought it would last after tune up but still it sounds like a tweeter. can anyone tell about that? is it detrimental to engine itself or is it normal like it need some kind of bloody repair? please i need some advice i'd appreciate your help. TIA!!! more horse power!!!
    squeeking sound = bearing problem/loose belts
    (possible bearing = idling bearing and your a/c compressor's bearing, worst scenario = wornout crankshaft pulley)
    tunog typewritter = needs valve tappeting adjustment.
    kailangan marunong talaga yung mechanic na gagawa nito.
    Nov 2007
    up lang kay zero? hm baka naman chamber like pressure cooker ang naririnig mo?
    Quote Originally Posted by zero View Post
    ive heard about tappeting magkaiba pa ba ito from tune up and valve clearance adjustment?
    yes its quite like typewriter sound 'tiktiktiktik....' pero mabilis.
    what if wornout crankshaft pulley? kailangan na ba ng overhaul?
    TIA! more power to you sir!!!
    Jan 2003
    valve tappets adjustment=valve clearance adjustment
    better have your crank pulley replaced if its worn out na. if not baka madamay pati crankshaft. overhaul talaga yun.
    Quote Originally Posted by non-vtec View Post
    makikita ba yun kung bubuksan yung head kasi napabuksan ko na yun recently nung nag pina tune up ko wala namang nasabi yung mekaniko sabi lang nya gasgas na yung camshaft kaya daw siguro maingay but im not quite convince tama kaya yun sir kasi mukang pang old school expert yung napagdalhan ko ano masasabi mo sir yun lang kaya talaga yun - gasgas na camshaft? please enlighten me. thanks!!!
    try to check with other mechanics. yung iba kasi may diskarte on how to isolate the sound. i have similar hissing noise sa engine ko last time, pinadinig ko sa mekaniko, then tinangal isa isa yung mga belts, then wala pa rin, hanggang sabi niya yung timing belt is adjusted to tight.
    dinare ko pa nga eh, sabi niya pag hinde natangal wag siyang bayaran. ayun after small adjustment natangal yung ingay na sinasabi ko.
    recommendation: try other reputable mechanic.
    Nov 2006
    Quote Originally Posted by slomo View Post
    ok lang yun kung sinabi ng mekaniko mo na gasgas lang,pero ang tanong kung saang parte ng camshaft ,sa may lobe o sa journal at kung acceptable ba ang klase ng gasgas.ang maganda mong gawin ay ipaadjust mo muna ang clearance ng valve kung mawawala o hindi at para malaman mo kung saan talaga nagmula ang ingay.bago mo ipagawa,itanong mo muna kung gaano kalaki ang clearance ng valve at cam lobe.kung hindi alam ng mekaniko huwag na dyan.humanap ka ng may alam.
    Jan 2008
    ano auto mo? model brand?
    Quote Originally Posted by alainroyce View Post
    honda esi po. btw naka headers, muffs, at simota kaya medyo confusing ang tunog, bearable pa naman kaya lang syempre nakakairita pa naririnig ko newbie pa lang kasi ako on this kind of car kaya medyo nangangapa pa. thanks nga pala to all your responses... madalang kasi talaga matyempohan (specially pag honda car) yung magagaling na mekaniko karamihan nasa kasa which also mean that you have to set your mind of costly expense. tsk tsk tsk...
engine noise?
