Results 1 to 12 of 12
    Jan 2009
    Guys ask ko lang, nag-exist ba yung engine na JDM D16b?? or is this the same of JDM D15B. nabasa ko kasi sa ibang thread ng ibang country na di ito nag-exist. Thanks
    I think it's the same engine as your local ph16 found in the EK vti civics.
    May 2007
    The D16b are non V-TEC single overhead cam and very weak engine.
    Get this one instead...the B16B (EK9)1.6L. 16 valve, 189 HP and the R.L 8400
    Apr 2004
    ^^ what a beautiful engine. i'd get one if i could afford one. but i want mine in automatic, heheh
    Dec 2003
    Meron atang matic niyan.Yung sa kakilala ko naka B18c matic.
    Anong engine ba yong sa Honda Esi '93 yong unang batch na pinasok ng Honda CBU from Japan? Nag stop na ang ODO from working at 97K+ mga 4 years ago pero maganda pa rin acceleration at tunog ng makina. Yon nga lang may slippage na ang auto trans minsan.
    Jan 2009
    wow nice red engine! pero paano malalamn kung D15B vtec sya and not D15B stage 3. may mga nakikita kasi ako na yung oil dip stick nya ay nasa in between ng headers then yung iba naman ay nasa side ng headers since physically same sila.
    thanks
    May 2007
    Quote Originally Posted by Blacktail View Post
    thanks
    A vtec engine there is a solenoid on the back of the left hand (looking in the engine compartment)side of the head. That's for a d series.
    For a b series the vtec solenoid will be right in front of the distributor.
    The D15B is a SOHC VTEC 1.5 (cc) 130 hp.
    The D15B2 is a SOHC 1.5(cc) 92 hp.
    The D15B6 is a SOHC 1.5(cc) 62 hp.
    The D15B7 is a SOHC 1.59CC) 102 hp.
    The D15B8 is a SOHC 1.5(cc) 70 hp.
    The D15Z1 is a SOHC VTEC 1.5(cc) 92 hp
    Apr 2009
    thanks
    d15b vtec jdm = 1 solenoid
    d15b vtec 3-stage = 2 solenoids
    Take note, pareho po silang VTEC .. and stage 3 is different from the 3-stage
    boss pano ba malalaman kung gumagana na yung vtec? kasi i just forcefully bought a vtec engine equipped car. the engine is new though. i heard from other enthusiasts that you'll notice the car's full potential with the vtec functioning.
    May 2007
    Quote Originally Posted by ram0722 View Post
    ON a VTEC engine there is a special camshaft that operates the valves. The camshaft has two sets of lobes on it. One set is designed to operate best at lower RPMs, the other set is designed to operate best at high rpms.VTEC does not make any noise when it is switching between one set of cam lobes and the other. IF it is setup correctly you won't feel it kick in either. It will be a smooth transition from one set of lobes to the other. On your car it probably switches over somewhere around 4,000 rpm
Is this engine exist??
