Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Apr 2006
    i downloaded a service manual for honda civic 92-96 model.
    however,inside the document, it references to engine d16z6 / d16z1..
    is this the engine of honda civic esi 95?
    Apr 2006
    san ka naka-download? penge ako
    basta yung local release was a D16 sohc non-vtec engine a.k.a. PH16
    Apr 2006
    almost 70 MB yund document1258 pages pero very informative and detailed...
    kasama din vtec.madami pala engines na sinusupport..
    thanks
    Jun 2006
    Quote Originally Posted by mazerom
    thanks
    pa-post naman po ng links pls
    thank you...
    Mar 2004
    ph16 bro...
    Sep 2005
    Kung masisilip mo, first 5 characters ng engine number ang model (e.g. D16Y3-xxxxxxx)
    Sep 2006
    The ESi engine is "PH16", which is basically a d16z6 with no VTEC, O2 sensor, and some other things missing. Also, due to the modifications, iba yung ECU nya, P27 instead of P28 for the "real" version.
    So yes, in the manual, you can use the specs for d16z6.
    HTH
    Jan 2003
    Quote Originally Posted by poch333 View Post
    HTH
    Sir, what about the "ph16" - vtec?
    Nov 2006
    hi to everyone! im looking for honda civic esi 95 model reasonable price sure buyer po ako thanks...
    Jul 2006
    buhayin ko lng to > ung ph16 sa ek 96-98 hindi ba vtev un? and san po ung user manual na link? TIA!
    Sep 2006
    There is a VTEC version of the PH16, I think it's called the "PH16A", found on the local EK models (VTi). This is the same as the ESi's engine, (derived from d16z6), but they kept the VTEC feature. Still no O2 sensor or cat, and of course a different ECU (sorry I don't know the ECU code yet). Honda also seemed to have done the "Throttle body coolant bypass" out of the factory; the coolant no longer passes through the EACV.
    san nyo po na download yung service manual? pa link naman po, tnx
    Mar 2005
    http://www.streetlegalkhk.nl/downloa...manuals/civic/
    very useful yung manual na yan! ;)
    92-95 civic ESi = PH16
    96-98 civic VTi = PH16A (vtec)
    99-00 civic VTi = P6JD5 (vtec) ewan kung bakit naiba ang engine code ng 99 model
    hth ;)
    Mar 2007
    thanks siR for the url link! it's very informative (useful especially when planning to replace stock engine) and whew... it's worth naman the waiting time for downloading via dial-up!
    Mar 2005
    dial up, langhya tagal nun bro ang tiyaga mo! :D
    well tha manual is well worth the wait, nanjan pati trouble shooting so if you are the DIY kin of guy you'll just open the manual and fix you own car ;)
    para san kaya yang throttle body coolant bypass?
    May 2007
    ok po ba gumamit ng twin carb intake manifold ng honda lx or mas maganda ang efi na intake manifold? help po
    Feb 2007
    Hi Guys,
    I have suspension system parts For Sale for your Honda vehicles. The brand is “ATLAS” and Made in Thailand. ATLAS Chassis Parts Corp. Thailand is under the license of ATLAS Chassis Parts Corp – USA (ISO 2000/QS 9000 Quality System Certified). Price is very affordable and all parts are guaranteed with 2 months warranty. The two (2) months warranty will start upon purchase and delivery of the parts. Mishandling of parts during installation is not covered by the warranty. Parts are packed in sealed plastic and box during delivery.
    The following are the suspension system parts available for Honda Vehicles:
    Balljoint Lower R/L Civic 92-95, DX, LXI, ESI P360 each
    CRV 96 – 00 model
    Balljoint Upper R/L Civic ESI 92 – 95, VTI, P340 each
    CRV 96 – 00 model
    Balljoint Lower R/L Accord 89 – 98 model P357 each
    Tie Rod End Outer Left Accord 89 – 93 P350 each
    Tie Rod End Outer Right Accord 89 – 93 P350 each
    Tie Rod End Outer Left Civic 93 – 96, CRV 96 – 00 P350 each
    Tie Rod End Outer Right Civic 93 – 96, CRV 96 – 00 P350 each
    Tie Rod End Outer Left Accord 94 – 00 P375 each
    Tie Rod End Outer Right Accord 94 – 00 P375 each
    Tie Rod End Outer R/L City 96 – 99 P325 each
    Rack End R/L Civic 89 – 92 P375 each
    Rack End R/L Civic ESI 93 – 96 P375 each
    Rack End R/L Accord 94 – 97 P375 each
    Rack End R/L CRV 95 – 99 P375 each
    Rack End R/L City 96 – 99 P375 each
    Stabililizer Link Front Civic, City, CRV P330 each
    For inquiry and order of parts, please call or text 09177448113, or email me at jcastillo312*yahoo.com or jcastillo932*yahoo.com. You can pick up the parts here at Makati Cinema Square Mcdonalds during office hours 9am to 6pm; and at Jolibbee Welcome Rotonda, Quezon City from 7:30 pm onwards.
    Thank you very much.
    Jay Castillo
    09177448113
    D16Y6, i think yan ung exact Engine code kc yun ung sa ESi ko.
engine code for honda civic esi 95 ?
