Results 11 to 20 of 41
March 25th, 2008 12:06 PM #11
- 13
March 25th, 2008 12:09 PM #12
March 25th, 2008 12:33 PM #13
- 27
March 25th, 2008 09:15 PM #14thanks mga Sir, post ko na lng auto ko pag lowered na, canvass na lng ako sa banawe and evangelista... thanks for the info...
http://tsikot.yehey.com/forums/image...ies/bowako.gif
March 25th, 2008 09:34 PM #15
ganon pala un... kala ko may problema na ung kotse namin. hehehe. dapat mag adjustable coil overs ako kaso talagang scrumbled egg ka daw sa kotse pag bumili ka nung mga r type. decided to buy a neuspeed lowering spring na lang, ok pa ung ride. halos same as stock lang.
- Dec 2003
- 131
- 27
March 31st, 2008 10:27 PM #18Sir, i decided to buy coilover na lang instead of lowering springs kaya lang pwede ba sa coilover yung stock shock ko... bka my convertion pa kya un...advice naman mga sir tenks.!!!!!
April 1st, 2008 05:50 AM #19
ngek! ganun pla talaga.. sna maaga ko pa nabasa i2ng thread na 2. e ngpalit na ko ng lower at upper arm e.. sayang.. sir flakez, ung sa kin scrambled egg din. stiff maxdo ride pero spoon (shocks) and 5zigen (spring) nkakabit dun. scrmbled eggnog pa dn. or tlagang stiff lang ang ride kpg nglower compare sa stock suspensions talaga? thanks mga sir!
April 1st, 2008 09:47 PM #20
sir there are sets na for coils, yung mga expensive like tokico and HnR... usually they have the set. pero if your going for the coil overs lang then ok lang yung stock muna na shocks pero ingat lang sa humps kasi malakas pa din and recoil ng fluid type. then kung bumigay na, then go for gas shocks na.
maam, yung spoon and 5zigen, usually para sa mga track na yung specs niyan kaya matagtag talaga. if you want the comfort.... go for the tien na streets or yung neuspeed na green is your best bet.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
