Results 1 to 7 of 7
    Jan 2010
    Ask ko sa nga guru jan, pwede ba isalpak ung d15b cylinder head sa PH16a engine? Meron kasi nagbebenta sa akin and gusto ko lang makasiguro kung pwede nga.
    Saan ba originally nakasalpak ang d15b engines? Ung sa honda civic vtec '96 ko ang nakasalpak is PH16A.
    Help naman po.
    Aug 2004
    Quote Originally Posted by advatech View Post
    Help naman po.
    It should fit.
    May 2007
    http://honda-tech.com/showthread.php?t=554053
    hth
    mini me swap tawag nila dyan. just refer to the link regarding the technecalities.
    http://s3.zetaboards.com/HCP/topic/394358/2/
    yan naman ang link ng mga taga HCP.
    Jan 2010
    Quote Originally Posted by mikhailer View Post
    hth
    Ung Ph16A ko is VTEC na rin sir so hindi rin pala applicable magpalit ng head from Ph16A to D15b magpapalit pa rin pala ng computer box. Mas magastos pa kalalabasan. Actually meron na ako nacanvass from evangelista na cylinder heads so doon na lang ako bili.
    Thanks sa info
    Aug 2004
    A JDM D15B head has better cams... but there's not really any big reason to swap out a D16/PH16 head for one.
    There's no problem with the compression from the heads... the compression is decided by the pistons and rods.
    Apr 2009
    Mag-aactivate ba yung wildcams ng d15b head when in the first place eh diba VTEC-E ang system ng ph16a?
    Can a P08 ecu compensate for that? Eh di bili din ECU to gain expected power?
    Jan 2010
    It should fit.
    Hindi kaya magkakaroon ng problem with the compression, D15b is for 1500 and Ph16A is 1600cc?
Does d15b cylinder head fits Ph16A engine?
