Results 1 to 10 of 10
- Nov 2008
- 18
January 23rd, 2009 05:55 PM #1ask ko lang po ano po kaya main roblem pag may oil leak between dist and head ano po kaya magandang gawin? TIA.. More horsepower!!!
- 27
January 23rd, 2009 09:06 PM #4
tama silang lahat, oil ring lang yan...alam ko meron inner and outer oil seal kung pagawa mo na lahat, para isang labor na lang.
- Nov 2008
- 18
January 24th, 2009 05:55 PM #6
bro pa ride na lang,
sa civic 96 meron din tunutulo drop lang naman sa distributor between sa cover at lower housing nito, saan kaya maganda pagawa ito at magkano ang cost labor and materials,
thank you po
January 25th, 2009 12:11 PM #7
- Nov 2008
- 18
January 28th, 2009 10:08 AM #8sir V6 di po ba maselan yung pagbukas ng distributor especially pag lilinisan form oil leaks kasi yung old school mehanic ko dati yun ang sabi complikado daw yun, pero yung o-ring sa rotor ok na ako na rin yung nagpalit ginuhitan ko na lang yung connection so far so good.
January 28th, 2009 03:23 PM #9
ganito din ang problema ng ek ko, magkano sir inabot lahat ng pag repair mo? oil seal at o ring daw yan, nagtanong na ako last month mga 500 yung 2 parts pa lang. madali lang kayang palitan ito?
- Aug 2008
- 48
January 29th, 2009 11:39 AM #10o-ring (with coil) inner at oil seal outer. Hindi yan makukuha sa three bond or any sealant, I suggest change it. Annoying kasi nababasa ng langis ang transmission at mga hoses. Kung matagal na yan malaman pati heater hose mo sunog at malambot na and candidate for blast of coolant. Check it out if this is something helpful.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
