Results 1 to 16 of 16
    Sep 2009
    mga sirs,
    good afternoon, ask ko lang po kung may idea kayo how much magpapalit ng crank shaft? pina check ko kasi sa honda they advise me to change the or repair the crank shaft dahil mauga at maingay yung crank shaft pulley. sa Honda kasi repair lang is 24k lahat. if ever repair lang may effect b?
    anung engine ba yan sir?
    Jun 2004
    Quote Originally Posted by j_gasmen View Post
    mga sirs,
    depende cguro sa model ng sasakyan, nung pinalitan crank shaft pulley ko dati umabot ng around 5k sa honda q ave.
    Sep 2009
    ph16 is my engine, not only the crank shaft was damaged also the crank shaft itself. that the reason why they will pull down the engine and repair the crank shaft. huh! laki gastos, what if I change to d16 or d15 how much will i SPEND?
    thanks,
    Halos ka presyo na ng surplus na makina ang repair ng crankshaft .
    Sep 2009
    sirs,
    may idea ba kayo magkano camshaft na brandnew at magkano din sa surplus.
    Last year nagpalit ako ng crankshaft and pulley sa civic 96 ko. Cost me 9k for the surplus crankshaft kasama na yung pulley and bearings sa evangelista. They took it from a ph16 engine with a busted engine block. Ganun daw dapat pag purchase kailangan nasa engine with oil pa wag daw yung mga nakasabit lang according to them. Labor for the installation umabot ng 10k kasi palit belts, mga seals, oil and painting ng engine bay, para na ring nag engine swap.
    Pero if I were you I would go for the repair sa casa. Maayos ang warranty. Yung sa akin sablay pa nung unang kabit e tapos pag binabalik ko nagsusuplado na yung mechanic na buset. Kawawa tuloy engine
    Jul 2014
    mga sirs,
    Sir meron ako crankshaft for 5k lng..nabusted kasi ang block ko..benta ko nlng piston at crankshaft both in verygood condition..pagkasama piston 8,500..txt me kung interested ka..cavite area ako paps
    Oct 2016
    Quote Originally Posted by wilson2 View Post
    Naghanap ako ng replacement ng Crankshaft sa d15b Honda civic....
    Jul 2014
    Kung gusto mo sir ng mura pwede Ka bumili ng pully at kunya lang.. Basta mahigpit ang bolt ng pully di un gagalaw..
    Tsikot Mobile App
    Apr 2018
    mga sirs,
    mahal putek me tama din sakin
    May 2018
    Quote Originally Posted by talabastardo1 View Post
    Nakapagcanvas ka sir recently?
    Yung quote sa akin sa isang shop 30k-33k kung repair. Labor (including palit gaskets and seals) and machine shop ng crankshaft.
    Another shop 15k labor, 18k machine shop (pero quote lang nila yang machine shop pwede pa mabawasan o madagdagan).
    Parang engine overhaul na rin kasi wala pa dyan yung kung may mga kailangan na rin ayusin/palitan sa ibang components ng engine
    Jul 2016
    Quote Originally Posted by abl View Post
    Pag ganyang presyo, kaunting dagdag na lang change engine ka na. Upgrade pa sa power and may spare parts ka pa from your old engine.
    Minsan, di rin natagal lalo na pag sablay machine shop pinagdalhan mo...
crankshaft replacement
