Results 1 to 16 of 16
    May 2013
    Hi Experts,
    I would like to seek your opinion on octane booster and gas treatment products in the market. I have a 2009 CRV, i have been experiencing knock and pings these past few months even on flat roads. I fill up with 95 octane gasolines most of the time. The hinda service advisor said the knock and pings are caused by low octane fuels.
    I wonder which one would help with my situation gas treatment or ocatne booster?
    Thank younfor your opinions and suggestions.
    JC
    May 2013
    Hi Experts,
    JC
    May 2013
    I fill up with Petron XCS and with Total. I get the same results
    What brand and type of fuel you usually use to fill-up your CRV? Do you fill-up from just one gas station or different stations? Maybe a different brand or filling from a different station will make a difference.
    Quote Originally Posted by jc24 View Post
    Hi Experts,
    JC
    Have the ignition timing checked first. If your car has a knock sensor have that checked, too (pero wala yata knock sensor ang honda?) And as suggested by egan101, try switching gasoline brands or stations, baka adulterated yung fuel sa favorite station mo.
    actually you don't need one.
    try to load up on the next octane variant to see if the pings are still there.
    and try to load up on a different station and a different brand.
    Jun 2011
    Hi Experts,
    JC
    have the combustion chambers decarbonized. at that age and mileage there is a big chance of carbon buildup. even if the carbon build up is not that bad, decarbonizing improves performance and fuel economy
    May 2013
    Sir how and where do Imhave it decarbonized? Current mileage is 58k.
    Jul 2011
    hinahalo lang po sa gas, ibinubuhos un sa tank, kung hindi ka sure better invest a little at ipagawa mo na lang yan sa honda casa.
    May 2013
    Quote Originally Posted by Manilablock View Post
    Thank you sir.
    Jul 2011
    try mo din sir reset ng ECU,
    disconnect the negative terminal of the battery for atleast 5 mins,
    connect it again and drive around the block for a few times to have the ECU relearn
    its settings.
    Decarbonizing is known also as an italian tune up. I usually do mine at nlex and sctex, preferably very early in the morning (3am or earlier). Just go there and floor the gas pedal. Make sure your brakes and tyres are up to the job before attempting this PMS.
    Then it is not the gasoline, it's the engine. Have the timing checked first. Then have it decarbonized. Carbon deposits lead to a condition known as "dieseling" wherein hot carbon parricles in the cylinder act as an ignition source, causing premature ignition of the fuel-air mixture. The resulting symptom is engine knock. In extreme cases dieseling can cause an engine to continue running even when the ignition has been turned off (not so with engines with electric fuel pumps though).
    Feb 2009
    hindi kaya tappet lang?
Octane booster or Gas treatment
