Results 1 to 8 of 8
- Sep 2010
- 173
May 19th, 2011 05:43 AM #1Hi
Pag akyat ko nung bridge biglang tumaas dahan dahan yung temperature. Pero bumaba temp nung hindi na paakyat.
Ano kaya problem?
May 19th, 2011 03:06 PM #2
ganyan din yung problem ng civic vti ko dati 98 model paoverhaul mo kung ganun parin ang probelem niya replace mo na ung radiator mo ng two rows radiator http://tsikot.com/forums/newreply.ph...7694&noquote=1
- Sep 2010
- 173
May 20th, 2011 07:14 AM #4Hi i test drove again my car kanina madaling araw. Pumunta ako kung saan incline ang road. Normal temperature.
So bumalik na ako sa bahay at nagpark. Naisip ko to turn ON the aircon before parking. Ayun biglang tumaas ang temp pero konti lang. Mga 1/8 to 1/4 itaas max above normal temp. Fluctuating.
I think its a relay problem aircon fan? or aircon motor fan itself?
May 20th, 2011 07:45 AM #5
- Sep 2010
- 173
May 20th, 2011 07:58 AM #6*ans_lim168
Hindi ko maalala kung bukas aircon nung una nangyari ito. Pero kanina ginawa ko nakailang limang ikot talaga ako. First yung OFF aircon so normal temp.
Nung On aircon nag try ako umikot ulit. Above normal temperature pero hindi na aangat ng mataas. Binilisan ko takbo kahit On aircon, above normal pa din. Pero pag magstop ako doon tataas ang temp.
Baka pasira na aircon motor.
- Jun 2010
- 36
May 20th, 2011 02:20 PM #7Nangyari na rin sa akin to. Thermostat and switch tapos flushed the water sa radiator. Okay na ulit. Sana makatulong.
- May 2011
- 6
May 29th, 2011 01:00 PM #8problema kasi sa honda engines alluminum yung cylinder head kaya madaling ma-bingkong. (esp kapag nag-over heat na cya before) kapag di na pantay yung cylinder head, nag co-cause na yan to rise the engine temperature.
Thank you!
