Results 1 to 10 of 11
- May 2012
- 87
October 27th, 2019 09:57 AM #1Hi guys I have a 2009 FD, alignment problem as it shifts to the left. Sent to Value Plus for alignment however they did not proceed kasi daw I have to fix /replace the following issues first
Rack pinion assembly
Tie rod end
Tie rod bar
Lower arm assembly
Front shock abs and components
Questions:
Reliable ba Value Plus?
Do I really need to replace these before they can align it?
How much will it cost me?
Where best to bring the car (Las Pinas area)
Thanks
- 54,260
October 27th, 2019 10:09 AM #2it is first rule in alignment: make sure your various components are within factory specifications.
it would be a waste of money, if one were to have his car aligned, with worn suspension parts. the alignment wouldn't hold true after a short time, if it can be aligned in the first place.
but whether your parts are still ok or not, is another question.
you can bring your car to another facility, for second opinion. and third opinion, if you so wish.
if they all say you need to replace some parts first...
they're probably right.
good luck.
- May 2012
- 87
October 27th, 2019 10:22 AM #3
- 54,260
October 27th, 2019 10:25 AM #4
- Aug 2017
- 321
October 28th, 2019 08:59 AM #5
- 54,260
October 28th, 2019 10:09 AM #6when i was still active in pre-owned and minana-from-dad car ownership, suspension and steering wear-and-tear evaluation was of the wiggle-it-shake-it method.
i do not know if this is still the way nowadays.
but if it still is, one can easily watch and learn.
October 28th, 2019 10:14 AM #7
- May 2012
- 87
October 28th, 2019 11:17 PM #8Thanks guys
Havent brought the car yet for a 2nd opinion but been thinking where to get replacement r&p assembly, just in case
Other shops/sources I can tap? Appreciate help in advance.
- Jun 2005
- 3,774
October 29th, 2019 12:34 AM #9
- 54,260
October 29th, 2019 12:36 AM #10
Here's the suspect: the oil sending unit . I replaced it over the weekend. I hope this...
Oil leak
