Hi! Honda Gurus,
I need your help/opinion to find out what cause the following problems:
1.a. the idling is somewhat high-around 900 RPM- but at the same time, kind of rough to the extent that vibrations can be felt inside the passenger cabin, most particularly on the dash and steering wheel;
b. when the gas pedal is pressed then released, RPM goes down to about 500, or less then goes back to 900. It's like "choking?" i don't know if that's the right term;
2. a. the A/T stays quite longer (than normal) in 3rd gear before shifting to 4th gear.
b. when in 4th gear, just a slight press on the gas pedal, will cause shifting to 3rd gear.
I hope you can help me on these problems. TIA!
