Results 1 to 17 of 17
    Apr 2010
    Hi, question lang g po mga sir, I have a honda city i-dsi 07 model w/ 17" mags, but my problem is gusto ko po i lowered yung springs, would it be necessary to buy lowering springs or to have them cut....help naman po mga pro, ung lowering springs po kasi medyo mahal instead of having them cut nlang, any suggestions po or advice,,,thnx tsikot...^^
    Cutting your springs is a no-no. It will just destroy your suspension underneath. There are brand new budget springs available, or yet, find on one the 2nd hand market - just make sure what you will be buying is original - if budget is really limited. If you still don't have enough cash, invest some. Patience is the key. Never resort to quicky alternatives, you'll just regret what you did in the future.
    Jan 2011
    Quote Originally Posted by johnkeight08 View Post
    TS wag ka magputol nang spring, sasakit lang ulo mo, you'll end up replacing damaged parts of your suspension due to your putol spring, may specific spring rate kasi mga yan.. Much better to invest on decent lowering springs, from what i've read sa forums, go for brands like H&R, tein, tanabe, etc..
    Never cut your springs. For one, the cut spring may not seat well and may fall off the spring perch and cause more trouble for you.
    You can fine either new or 2nd hand lowering springs for your car. If you want brand new, you can check out the numerous car tuner shops around the city. BTW, once you have your new springs installed, remember to have your car's wheel alignment checked and adjusted.
    Apr 2010
    Thanks po sir GH, thats really a very good advice, ty po ulit buti nlang didnt have the time to have them cut or checked but thanks again sir,,,,and to tsikot more power!...=)
    Apr 2010
    BTW, sir any advise regarding shops that are selling cheap but good quality lowering springs?...thnx again
    Oct 2009
    Kalimutan ko name ng shop. Pero sa banawe marame Maxspeed ang brand around Php 7-8K. Bawal po pala dito ang text speak sir :-)
    Aug 2010
    Wouldn't just buying lowering springs compromise the whole vehicle's suspension? Alam ko kasi pagmagpapa-lower ka, you compromise it with adjustments to the other suspension parts diba?
    Oct 2009
    Quote Originally Posted by jhnkvn View Post
    Yes po, you need to cut the bumpstop of your shocks into half pag nag lowering spring po kayo.
    Not really compromise the whole vehicle's suspension. Usually "street" level springs are only marginally stiffer than stock so the original shocks will work fine. To gain back a bit more suspension travel, the shock's bumper is cut shorter but should not affect it's service life.
    How would you consider "cheap"? ... running price would be P12.5K at Speedlab for TEIN springs.
    hanap ka nalang ng mga tipong Maxspeed, Whiteline etc.
    Nov 2014
    Any update san nakabili lowering springs na ok at mura?
Honda city lowering springs or putol?
