Results 1 to 13 of 13
    Guys I need your expert opinion/advise
    I have an Aircon problem with my 2004 Honda CRV (2nd Gen). May times na hindi lumalamig ang aircon ko. I notice pag mainit or nabibilad sa araw ang CRV ko, tsaka di gagana ang aircon.
    Tinest ko kung nag eengage ba ang clutch nito by turning on and off the AC switch habang umaandar ang makina, nag chachange naman ang RPM niya so sa tingin ko wala problem dun na part. Di lang ako sure kasi hindi ako expert pero sa tingin ko may problema sa temperature sensor or thermostat ba tawag dun na siyang nagdidictate ng coolness output ng aircon. Tama ba ako?
    O di kaya may vent na hindi nag oopen kaya di makapasok sa loob ang cool air?
    Pag umandar yung aircon ko, wala talaga akong masabi kondi normal lahat pati yung temperature control at blower so i think wala problem sa freon. Pag di naman, ay naku bumubuga ng medyo mainit na hangin pati ulo ko umiinit. May maluwag lang kaya sa loob (electricals) nito?
    Please and thanks for the help guys...
    Nov 2007
    Quote Originally Posted by rax06 View Post
    When was the last time you had it cleaned? If it has been a year or so maybe it's time to have it serviced.
    check the fans
    Sent from my iPad using Tapatalk HD
    Mar 2011
    Busted ba yung dome light?
    Nov 2011
    I had the same problem with my CRV 03. It's gotta be the fan motor. pag nawala na pati blower, then pati capacitor na yun.
    Jun 2011
    baka mataas masyado or mababa ang settings mo ng thermostat? or it could be high pressure possible mahina or hindi gumagana a.c. aux fan mo sir... pwede din condenser mo po ang may deperencya madumi or barado na kaya nag high pressure ang a.c. mawawala po talaga ang lamig...
    Aug 2003
    Sir kapag umaandar ba lalo na sa gabi at mabilis malamig yung aircon then kapag traffic/idle nawawala lamig? If so baka aux fan.
    Actual experience ko sa 2003 CRV namin was tumataas yung temp guage pati di masyado malamig. Barado daw condenser nun at high pressure. Pinalitan ok na.
    Naexperience ko rin leaking evaporator, walang amoy pero noticeably mahina talaga pag lamig.
    Sabi pa dati, ang mahihinang components ng CRV aircon ay condenser at compressor. so pacheck mo na lang sa aircon shop para madiagnose at second opinion sa iba before mo talaga ipagawa.
    Jun 2011
    Quote Originally Posted by ek2jayvee View Post
    sir yung condenser may alam ako may pang linis sila ginagamit na pang condenser... hindi kailangan nang palitan... malaki po matitipid
2nd Gen Honda CRV Aircon Problem
