Results 1 to 10 of 13
- Nov 2008
- 9
September 24th, 2012 01:44 PM #1Guys I need your expert opinion/advise
I have an Aircon problem with my 2004 Honda CRV (2nd Gen). May times na hindi lumalamig ang aircon ko. I notice pag mainit or nabibilad sa araw ang CRV ko, tsaka di gagana ang aircon.
Tinest ko kung nag eengage ba ang clutch nito by turning on and off the AC switch habang umaandar ang makina, nag chachange naman ang RPM niya so sa tingin ko wala problem dun na part. Di lang ako sure kasi hindi ako expert pero sa tingin ko may problema sa temperature sensor or thermostat ba tawag dun na siyang nagdidictate ng coolness output ng aircon. Tama ba ako?
O di kaya may vent na hindi nag oopen kaya di makapasok sa loob ang cool air?
Pag umandar yung aircon ko, wala talaga akong masabi kondi normal lahat pati yung temperature control at blower so i think wala problem sa freon. Pag di naman, ay naku bumubuga ng medyo mainit na hangin pati ulo ko umiinit. May maluwag lang kaya sa loob (electricals) nito?
Please and thanks for the help guys...
September 24th, 2012 01:55 PM #2
Registered User
- Mar 2011
- 276
- Nov 2011
- 79
September 29th, 2012 04:57 AM #5I had the same problem with my CRV 03. It's gotta be the fan motor. pag nawala na pati blower, then pati capacitor na yun.
September 29th, 2012 07:34 AM #6
baka mataas masyado or mababa ang settings mo ng thermostat? or it could be high pressure possible mahina or hindi gumagana a.c. aux fan mo sir... pwede din condenser mo po ang may deperencya madumi or barado na kaya nag high pressure ang a.c. mawawala po talaga ang lamig...
- Aug 2003
- 317
September 29th, 2012 08:02 AM #7Sir kapag umaandar ba lalo na sa gabi at mabilis malamig yung aircon then kapag traffic/idle nawawala lamig? If so baka aux fan.
Actual experience ko sa 2003 CRV namin was tumataas yung temp guage pati di masyado malamig. Barado daw condenser nun at high pressure. Pinalitan ok na.
Naexperience ko rin leaking evaporator, walang amoy pero noticeably mahina talaga pag lamig.
Sabi pa dati, ang mahihinang components ng CRV aircon ay condenser at compressor. so pacheck mo na lang sa aircon shop para madiagnose at second opinion sa iba before mo talaga ipagawa.
September 29th, 2012 08:13 AM #8
- Nov 2008
- 9
October 2nd, 2012 01:24 PM #9Guys salamat talaga sa mga opinion and suggestions nyo. I checked the fans and blower last Sunday, lahat naman gumagana. All the fuses in the fuse box internal and under bonnet walang busted. Only to find out wala na yatang freon. Habang pinatakbo ko ang makina at A/C, wala man lang ako nakita ni bubbles sa sight glass. hinawakan ko ang low and high pressure tube/pipe eh para wala lang. walang lamig o init sa dalawa. Hopefully sa freon lang to. My A/C pala was serviced 3 years ago..
May other possibilities pa kaya na nag cause nitong problem na to like expansion valve or anything?
Hahayyss.. hirap pala pag maniningil na yung sasakyan. Ang mahal pa ng OEM parts ng honda. Dami pa problema sa CRV but no doubt i really love my CRV.
- Apr 2007
- 20
November 7th, 2012 03:09 AM #10bro,pls check the plug-in component under the glove compartment....if i'm not mistaken eh resistor/transistor
package un * medyo costly.symptoms nya eh on/off * intermittent ang lamig ng ac till nawala na ng tuluyan at di na mag-on ang ac...nangyari sa crv-03...tnx and good luck.....
