Results 1 to 8 of 8
    Apr 2010
    Mga sir question lang po, ano bang problema kapag nag faflactuate yung ilaw and pati ung sounds. Minsan ok yung oto pero madalas mangyari to. Ginagawa ko nalang is, itabi yung koche tapos patay makena tapos start ulit. Minsan nawawala then babalik ulit. Nakakainis. Para kang mamamtayan ng makena habang umaandar. Tulong naman po. TIA.
    Dec 2007
    Seems the problem is electrical in nature.
    Check the following:
    - battery
    - alternator
    - grounding
    - fuses
    - have a mechanic look for any short circuits
    Nov 2006
    Quote Originally Posted by Type 100 View Post
    - battery
    - alternator
    - grounding
    - fuses
    trace mo wiring connections sir baka nga me maluwag like sa battery terminal or grounds...
    Jan 2009
    Most likely causes:
    1. Loose battery connection
    2. Defective or loose main relay
    Pag na check mo na iyong mga sinabi nila pa install ka ng Grounding kits para maging stable ang mga ilaw mo at menor ng sasakyan.
    Apr 2010
    salamat sa mga tips mga sir. magkano po ba ung grounding kit?
    Quote Originally Posted by milesdsc View Post
    Loose battery clamps or bad connection (due to corrosion) at the battery clamps.
    Loosen, clean and reinstall.
City Type Z A/T Problem
