Results 1 to 14 of 14
    Feb 2010
    mga sir newbies po k d2 bka m2lungn nyo k s prblem k, my car is civic vti 99 mdl the prblm is my tme po n d a2ndar ung oto like k2park k lng den i2strt k ult ayw n pong umndar pero mlks po ung btery k pag kinadyot nmn po a2ndar but ang taas ng rpm k nsa 3rpm k d n po sya baba once pinty k ult d n nmn a2ndar tpos pag pingphnga m ng 30min or 1 hour a2ndar n sya den normal po ung rpm nya.. wat po kya prblem nito nsa redondo po b or starter? help po mga bosing
    Quote Originally Posted by heartie View Post
    [SIZE=3]Text speak is not allowed in tsikot.
    Read the rules.
    [/SIZE]
    Your battery is how old already ?
    To double check, have the charged measured. Libre lang naman iyan eh.
    Try mo din pacheck alternator mo.
    Feb 2010
    *2 renzo
    bago na po ung alternator ko,pero ganun p rin ung problem ung batery 9months p lng, ung kahapon ayaw umandar nasa banawe ko tiningnan ng mekaniko dun ang sbi s redondo dw problm kailngn daw linisan, d ko na po alm tlaga kung wat problem tpos bigla n lang mag chech engine once pinatay m hndi na babalik ung ilaw sa chck engine.thanks sa reply po
    ang hirap namang basahin! ano bang ginamit mo, cellphone??!
    Feb 2009
    *2 renzo
    do you need to encrypt your message? you need help or what. do you expect to get help?
    [SIZE="4"]Reminder: no posting messages in SMS/TXT format.
    Learn to spell words properly.
    Read the rules.
    Ignorance of the rules is not an excuse.
    Repeated offenses will lead to banning.
    [/SIZE]
    Aug 2008
    bossing try mo diagnosed kung ano ung code ibabato ng check engine mo...
    di ko rin ma gets yung message psot mo... di ba pag on mo iilaw ung check engine or di na umiilaw???
    Jun 2010
    battery and alternator is not the problem.
    first, try to check grounding of the car.
    second, ipalinis ang MAF sensor dahil erratic idling ka, ayun lang ang culprit based on your qeustion.
    my 2 cents.
    Feb 2010
    mga sir newbies po ko dito baka matulungn nyo ko sa problem ko, my car is civic vti 99 model the problem is my time po na hndi aandar ung oto like kakapark ko lang then iistart ko ult ayaw na pong umandar pero malakas po ung battery ko pag kinadyot naman po aandar but ang taas ng rpm ko nasa 3rpm ko hndi na po sya bababa once pinaty ko ulit hindi na naman aandar tapos pag pinagpahnga mo ng 30minutes or 1 hour aandar n sya then normal na po ung rpm nya.. what po kaya problem nito nasa redondo po b or starter? help po mga bosing
    Feb 2010
    *ben david
    what po ibig sabihin nung MAF sensor? saan po banda makikita yun? and saan ko po pwede palinis?
    [SIZE="4"]REMINDER: do not post in SMS/TXT format.
    Read the rules.
    [/SIZE]
    *ben david
    MAF is a type of air flow sensor that is typically located just behind the air filter and/or along the air intake tube of your car's engine.
    Mar 2007
    Kulit talaga oo!
    Baka kailangan tagalugin na mods....
    BAWAL TEXT SPEAK PO!
    - If you have a scanner...get the code to diagnose the problem.
check engine lights
