mga boss, tanong ko lang po kung swak ung cylinder head ng ph12 sa ph16?
ilovemyhonda..... one thing for sure.... downgrading the engine from ph16 to ph12 is not a good idea.... i would recommend na lang to use a d15b ch to the ph16 block.... as a mini me.... it will give you the function of vtec, 20 valves lobes and fuel efficinecy if the ecu (computer box) to be used is well tuned... one more is magpapalit ka din pala ng ecu from p27 to p08...
*isa1023.... fyi its not because it say ph12 it has 12vlaves sir.... ph12 means thre engine has a displacement of 1200c/cm or 1195c/cm and ph16 has displacement of 1600c/cm or 1595c/cm....
Mr jemm01, hehe oo nga no sinearch ko din. 4 valves per cylinder nga yung d12 engine
^^Up... much better use internals from D engines with higher or at least equal capability as with the ph16 engine...![]()
