Results 1 to 6 of 6
    Feb 2010
    mga sir hinge lang ako last opinion sa inyo.. e2 kasi ang scenario.. everytime i start my car tagal mawala ng check engine light and not starting xa habang naka check engine.. ask ko na din kung lahat ng honda ganun tlga kelangan mawla check engine light bago i start ang kotse, my iba kasi kami car naka chek engine light on xa pero nagsstart naman nissan nga lang ang tatak.. galing na ko talyer napagastos ako sa fuel pump relay nde nman pala un problema nde ko tuloy binayaran ang mekaniko, ayaw na kasi ibalik nung pinagbilhan ko ung pera eh.tapos na rerepair naman pala un hinang lang katapat.. pa comfirm naman kung ecu ko na tlga problema or ano sa tingen nyo??
    Jul 2010
    paupdate mo lang ecu mo,baka yan lang ang problema.
    Quote Originally Posted by ninzky View Post
    hi! is your car an Esi? i had a 1993 honda esi before and had the same problem. i had to turn the keys on and off several times before the check engine lights go off. A car electrician worked on the ecu under the glove box and the starter relay under the steering wheel. but i have this strong feeling it was the faulty starter relay that was causing it.
    Yup, check the ECU. But before that, check the sockets first. Baka may hindi lang nakabit ng maayos.
    old electrolytic capacitors on the ecu could mess up reset/power-up routine ... have them replaced by a competent electronic technician ... mura lang yung mga capacitors, mas mahal labor ng tech
    yes sir possible ecu problem. same problem tayo nuon,sakin nga more or less 5mins pa bago mawala CEL.di naman ngsstart kapag nka on pa CEL.
    got my ecu changed. programmable nga lang yung pinalit ko.
    yun,ok na.2secs wala na CEL.
Check engine light
