Results 1 to 7 of 7
- May 2011
- 4
May 31st, 2011 12:50 PM #1ano po kaya problem ng esi a/t ko, pag patakbo nko ng matagal n naka on ang a/c or headlights, tpos iilaw ang check engine.. help nmn po mga experts..salamat,.,
May 31st, 2011 01:02 PM #2
boss mahirap identify kung ano problem ng check engine. kailangan basahin kung ano yung fault code. pwede diy yan if you want or pwede paread sa mga shop.
- May 2004
- 903
May 31st, 2011 01:03 PM #3Try ninyo muna Reset ECU by disconecting Battery terminal for about 30min.. then pag ganoon pa rin have your car check kung anong error ng ECU... from there you will know what to do...
- Jul 2003
- 573
May 31st, 2011 10:29 PM #5
dapat diyan pa basa mo ang code, hanap ka na lang ng malapit sa iyo ng marunong magbasa ng CEL, taga saan ka ba?
- May 2011
- 4
- May 2011
- 4
June 3rd, 2011 01:36 PM #7Ng palit na po ako battery, so far so good.. Wla pa check engine indication... Thanks po sa inyo lahat..
high idle RPM at engine start
