Results 1 to 10 of 16
- Aug 2010
- 53
August 17th, 2010 12:58 PM #1Mga sir ano po kaya possible causes ng check engine light ko.Umiilaw po siya pag 60kph tapos 2200+rpm.Marereset lang po siya pag nirestart ko uli engine pero once na bumilis po ulit ako iilaw po ulit siya.Wala naman po akong ramdam sa makina.
August 17th, 2010 10:18 PM #2
it might be as small or big issue but based on what you said baka block yung prob. loosing compression or something. i not that sure, paread mo yung error code. sandali lang yan pero medyo mahal. dati 1k ata pacheck yung ECU
- Aug 2010
- 53
August 17th, 2010 10:49 PM #3Sir archie thanks po for the reply,ganun na ngapo siguro gagawin ko. Papa MUT ako sa kasa.Sana minimal lang ang problema.
August 17th, 2010 10:54 PM #4
most likely EGR or PCV issues yan. Do an ECU diagnostic scan with your trusted CASA
- Aug 2010
- 53
August 18th, 2010 11:48 AM #5Dito ako ngayun sa kasa,less than 3k magagastos ko.Eto list
change oil/filter/labor =875
ecu test for check engine light =400+
sparkplug replacement 600+
valve clearance and timing belt check-up =800+
Sabi baka ang cause nung check engine light is speedometer,possible kasi nagpalit ako ng mga bulbs sa gauge.
August 18th, 2010 12:24 PM #6
- Aug 2010
- 53
August 18th, 2010 12:55 PM #7Kasi sir di pa naman nachecheck kaya baka.Anyway I'll keep you updated kung ano problema.Dipa tapos eh diko ako sa lounge area.Tnx
- Aug 2010
- 53
- Jun 2010
- 76
August 24th, 2010 11:23 AM #9sir marami na niyan sa banawe mabibili..kay baltaks..engine master,or kay salvador...
- Aug 2010
- 53
