Results 1 to 20 of 24
    Jul 2010
    good day all.... need help in finding an expert mechanic to check the idling problem on our 1996 honda civic vtec.... idling drops , and at times engine turns off...
    thanks..
    Nov 2007
    Had you tried replacing your spark plugs? I think this one will define your problem.
    Jun 2008
    hello mga tsikoteers...hingi lang po ng tulong.
    our car is honda civic vti 96 model AT with d15b engine.
    ang problema ay mataas ang idling pag start then pag shift na
    sa D namamatay na po ang makina. spark plugs are new.
    thanks in advance.
    Oct 2009
    Quote Originally Posted by mact_tors View Post
    thanks in advance.
    clean to cleaning throttle body.sensor.
    d15b ibig sabihin nagpalit na ng makina dyan.pinalitan din kaya ng com box yan.
    Jun 2008
    Quote Originally Posted by jaypee10 View Post
    hi jaypee...nung 2010 pa nagpalit ng makina at kasama din sa pinalitan yung comp box. last week lang nangyari yung problema.
    sabi ng mekaniko kanina baka daw electrical o computer box.... may kinalaman kaya sa electrical yun?
    ipalinis ko lang yung throttle body sensor? pwede ko ba "DIY" yun? thanks!
    May 2016
    go first for the easier part before trying else others method, try to clean your throttle body and IACV with carb cleaner, if still no effect then go for other option.
    Jul 2016
    thanks in advance.
    sir ganito din po prob ko? ano po bang solusyon?
    tapos yung akin parang hinihika humabahol sa pag hinga yung engine kapag nakapatay air con sa P and N pero sa D naman okie na..
    tapos madalas tinaasan ko minor kasi namamatay pag naka open aircon kasi bumababa yung minor.. , okie sya..kapag tumagal tapos pag nagamit na ng matagal.. biglang baba uli then nahinga na pag naka P and N..
    tulong naman mga honda experts pls.. thank you..
    Dec 2009
    Ganito rin problem ko.... ano kaya ang dapat gawin... nagpalinis na ako IACV and ganon pa din ang idling... any suggestions will be of great help....
    ^ check mo iyong tps (throttle position sensor). baka busted na siya
    Dec 2009
    Up for this.
    Dec 2017
    Hi Mga Paps,
    Good day! Ask ko lang po anu kaya prob sa 95 honda civic esi (P16 valve engine) aircon system ko. bought the car a month ago and have it AC back to service last week. palit po ako compressor, filter at evap valve, palinis condenser, evap at tubings due to black oil contamination.
    Working naman po, pero ang prob at a certain time mga 10- mins malamig pa singaw pero after it lasts to 10 or more mins umiinit po ang singaw na inilalabas niya. Sabi ng Mech na napaggawaan ko po, sa timing lang yun. Anu po masasabi ninyo? First graceful car ko po kasi to kaya worried ako. tapos RPM niya when AC is turned on nasa 800 to 1100 fluctuating. magalaw kamay nung RPM. nataas/nababa...
    maraming salamat po mga Paps in advance.
    Try nyo pa ayos kay forced speed. sa loyola heights shop nya kung fi ako nagkakamali. Kilala yan dati sa honda forums (hcp). Google nyo na lang contact nos and loc nya
    Dec 2009
    Been years since my last visit to Forced Speed. Try ko bumisita ulit. Salamat Sir Baludoy.
    Jun 2017
    Clean servo sensor before going anywhere
    Jul 2017
    Nangyari na sakin to, I changed my sparkplugs and naging ok na agad.
    Jan 2010
    Quote Originally Posted by Honda4life View Post
    Can you post a picture of this "servo sensor"?
1996 honda civic vtec idling problem
