Results 1 to 10 of 24
- Jul 2010
- 1
July 1st, 2010 03:07 PM #1good day all.... need help in finding an expert mechanic to check the idling problem on our 1996 honda civic vtec.... idling drops , and at times engine turns off...
thanks..
- Nov 2007
- 39
July 3rd, 2010 05:04 AM #2Had you tried replacing your spark plugs? I think this one will define your problem.
- Jun 2008
- 81
March 13th, 2016 03:48 PM #3hello mga tsikoteers...hingi lang po ng tulong.
our car is honda civic vti 96 model AT with d15b engine.
ang problema ay mataas ang idling pag start then pag shift na
sa D namamatay na po ang makina. spark plugs are new.
thanks in advance.
- Oct 2009
- 2,271
March 13th, 2016 04:38 PM #4
- Jun 2008
- 81
March 13th, 2016 05:19 PM #5hi jaypee...nung 2010 pa nagpalit ng makina at kasama din sa pinalitan yung comp box. last week lang nangyari yung problema.
sabi ng mekaniko kanina baka daw electrical o computer box.... may kinalaman kaya sa electrical yun?
ipalinis ko lang yung throttle body sensor? pwede ko ba "DIY" yun? thanks!
- May 2016
- 6
June 23rd, 2016 02:17 PM #6go first for the easier part before trying else others method, try to clean your throttle body and IACV with carb cleaner, if still no effect then go for other option.
- Jul 2016
- 1
July 1st, 2016 03:48 PM #7Hi po,slight same issue po sa kotse ng husband ko Honda civic vti 96model magic.Kay problem ang idle rpm nya.pag walang aircon ang taas ng rpm NSA 1500,pag naman may ac sobrang bagsak halos mag 0 n.bka dlawa palit narin ako ng servo Japan surplus mhal kc Bago.Bago nrin ang alternator. Nadala ko n rin sa Mekaniko khapon sa banawe doon Na rin napalitan ng pangalawang servo. Wala pa,rin nangyare.ang sabi sken bka my problem Na computer box ko.may nirefer silang elec.named was jess.chineck nya ung computer box at ang sabi sira ang connection sa serbo at ibbalik din daw yung check engine.pero dko muna pinahinang ung my problema sa computer box para sure.I need some second opinion muna. . any suggestion po dapat ggawin.help.thanks
July 1st, 2016 03:51 PM #8
- Jul 2016
- 2
July 27th, 2016 03:32 PM #9sir ganito din po prob ko? ano po bang solusyon?
tapos yung akin parang hinihika humabahol sa pag hinga yung engine kapag nakapatay air con sa P and N pero sa D naman okie na..
tapos madalas tinaasan ko minor kasi namamatay pag naka open aircon kasi bumababa yung minor.. , okie sya..kapag tumagal tapos pag nagamit na ng matagal.. biglang baba uli then nahinga na pag naka P and N..
tulong naman mga honda experts pls.. thank you..
- Dec 2009
- 41
May 4th, 2017 06:53 PM #10Ganito rin problem ko.... ano kaya ang dapat gawin... nagpalinis na ako IACV and ganon pa din ang idling... any suggestions will be of great help....
