Results 1 to 10 of 22
- Apr 2012
- 80
November 27th, 2013 04:53 PM #1Hi guys. I have read lots of recommendations here but I also have lots of questions so I decided to make my own thread. I wanted to have my engine oil changed. Where should I buy the engine oil? Is it still safe to drive my car because I am already in 6.4K km (should be 5k right?) and the oil is already black. Can you suggest a place nearby? This is my first car by the way and what else should I check? Spark plugs, etc.?
I also observed lot of things to be checked. Sometimes I could smell a small burn on my clutch when I open my car door but not really always. It only happens if I am stuck for a long period of time on inclined road or with heavy load. Few times also, I find it slightly hard/sticky to shift from 3rd gear to 2nd gear if I am still in a fast motion.
I hope I won't spend over 6k php for everything.
Thank you!
- Oct 2013
- 20
November 27th, 2013 05:03 PM #2Sir, anong engine oil ginamit nyo jan last time? sa 6.5k sir kailangan nyo na magpalit ng oil para rin po sa engine nyo yun. ako ginagamit ko bardhal yung color gold yung label or yung sa honda mismo.
and yung sa clutch mo baka po laging nakatapak kayo sa clutch mangangamoy po talaga kung ganon lalo kung inclined road tapos di ka bibitaw sa clutch, advise lang siguro kung ganon nasa inclined road ka magneutral ka then tapak ka lang sa brake or pwedeng magbrake ka nalang.
sa shifting mo naman po ng gear check mo yung atf baka palitin na rin. kaya may konting sabit.
- Apr 2012
- 80
November 27th, 2013 05:13 PM #3
- Oct 2013
- 20
November 27th, 2013 05:21 PM #4Honda Civic ES 2001 po akin sir dapat sir pagkabili nyo pinatune up nyo po agad. palit lahat ng oil, spark plug, timing belt para po alam nyo kung kelan kayo magpapalit ulit. ganon po kasi ginawa ko dati saken dati. tsaka nyo po pag aralan kung ano yung mga ibang problema ng car kung meron man. yung oil na gamit P350/liter lang, yung atf para po sa transmission yun.
- Sep 2013
- 630
November 27th, 2013 05:27 PM #5Ganito lalo na first time ka. Wag ka didirecho sa talyer dahil lahat ng parts doon papatungan ka. Example ang vic sa mga talyer nasa 250-270 pesos. Pero sa car parts shop sa banawe eh 150 lang.
Sa kotse mo pwede ang engine oil na API rating na CI-4/SL. (example delo gold 15w40, idemitsu extreme touring 15w40 CI-4/SL. Partneran mo ng oversize filter na baldwin b1431. Meron yan nagtitinda sa sta mesa near mezza residence. Pwede mo paabutin 10thou-12thou kms. Pero pag vic oil filter gamit mo hanggang 5thoukms palitan mo na.
- Apr 2008
- 1,557
November 27th, 2013 05:32 PM #6*lloydi12345: Sir, taga Fairview ba kayo?
Alamin niyo muna kung anong klaseng oil ang ginamit. Kung FS oil kasi, pwede pa yang 6.5k kms. Ako sa Honda Fairview nagpapa change oil noon but now, I bring it to Speedyfix in San Juan. Pero sa service other than tune up and change oil, sa Honda Fairview padin kasi malapit so very convenient for me. Pinapaabot ko ng 8k kms ung akin kasi FS oil naman. Pero kung mineral oil lang yan, dapat palitan mo na. Feel the oil sir, kung medyo grainy na or magaspang, palitin na pag ganon.
If budget is a constraint, try going to Unioil for change oil. They are using Idemitsu, if I am not mistaken. Yan din daw ang ginagamit ng Honda pero rebadged siya. Pwede din sa Abante Marketing, sila ung previous Good Year shop malapit sa North Fairview. Pwede din ung Yokohama near Tandang Sora. Diyan kasi ako bumibili ng gulong and nakikita ko na andaming nagpapa change oil sa kanila. There is also Influx. Or in Shell, Don Antonio. Karamihan naman ng gasoline stations they offer tune up and change oil. Wag ka lang pumunta sa Rapide.
Kung FS oil ang gagamitin mo, pasok pa siya sa inaasahan mong hindi ka gagastos ng 6k. Pero ung sa smell of burned clutch smell, medyo mahirap malaman kung ano ano ang kailangan palitan diyan. They need to check where that smell is coming from. Pwede din kasing brakes ang may problem.
Yes, ATF means Automatic Transmission Fluid pero pwede yan sa M/T. Yan ang nilalagay sa mga auto namin pero manual naman.
November 27th, 2013 05:32 PM #7
- Apr 2012
- 80
November 27th, 2013 05:54 PM #8Oo nga sir eh, magpapatune up na lang ako pag nagpachange oil ako. Ilang liters po yung kinailangan mo? every 5km po ba yung change oil niyan?
Parang maganda yung delo gold 15w40 sir. Magkano po iyon? Yung filter na baldwin b1431 para saan and how much din po?
Opo sir bandang north caloocan ako. Few mins. lang naman to SM Fairview. Saan yung honda fairview? Ako na lang po ba bibili ng engine oil tapos magppachange oil ako sa honda fairview? Plan ko po muna mag delo gold. Ano yung tawag sa parang over all check up sa buong car? Para palitan ko na rin kung dapat may palitan. Sa speedyfix parang gusto ko rin itry.
Salamat po sa mga reply niyo
- Sep 2013
- 630
November 27th, 2013 05:56 PM #9^
Idemitsu diesel sa unioil - 980 4liters
Baldwin B1431 - Near mezza residence yung store sa guirayan street. Sa volmax nalilitan na ako sa B1402.
Delo gold.- May promo sila ngayon
Meron din idemitsu pero JASO rating. DH-1. Hindi ko sure kung ano counterpart sa API rating. Ok yung TBN.
http://www.idemitsu-ils.com.sg/Uploa...5W40%20DH1.pdf
- Sep 2013
- 630
November 27th, 2013 06:06 PM #10Yung baldwin at fleetguard ay heavy duty filter. Micron filtration rating below 20 microns. Ito ang filter na ok gamitin pag type mo umabot ng 10,000-12,000kms change oil.
Ang oem at vic oil filter eh 40microns. Hanggang 5,000kms palitan mo na.
Unioil contact number - 2549796
Baldwin B1431 and Fleetguard - 0917-9028570
Thank you!
