Results 1 to 8 of 8
- Feb 2010
- 33
September 27th, 2010 10:46 PM #1mga sir ask lang po pagnag pa change oil po ba need po ba palitan ang fuel flter, air filter and oil filter? and kailangan po ba mag adjust ng timing belt? thanks po sa magre2ply vti 99 po oto ko po
- Aug 2009
- 349
September 27th, 2010 10:51 PM #2
YEs! everytime ka magpapalit ng oil need to change, oil filter. But fuel filter kapag hirap na mag start up engine mo my clogged na.air filter depends kung marumi or clogged na sa dumi yung screen ng filter at mausok na car mo. Timing belt kung maluwag na at kung manipis at maingay na need to change new one!
- Aug 2010
- 11
September 27th, 2010 10:53 PM #3Oil filter lang ang kelangan mo palitan, pag marumi na yung air filter saka mo lang yun papalitan, yung fuel filter pag walang pumapasok na gas sa engine initial symptoms it won't start
- Aug 2010
- 11
September 27th, 2010 10:55 PM #4anyone, may alam ba kayo na tindahan ng REPSOL ELITE 5W50 na langis dito sa P'que sa pasig lang kasi ako huling nakabili ng langis na ito eh, and maganda ang takbo ng auto ko dito super tahimik ng engine at walang vibration di gaya ng CAstrol magnatec meron pang konti... thanks
September 27th, 2010 10:58 PM #5
for change oil ang kailangan oil, oil filter, at sa ibang nabangit mo merong mga ibat ibang maintenance inteval time sila.
change oil and oil filter every 5000 km
sa iba hintay natin input nila
fuel filter
air filter
replace timing belt and water pump
additional: spark plug
- Feb 2010
- 33
- Feb 2010
- 33
- Nov 2009
- 456
September 28th, 2010 12:15 AM #8The air filter element is usually inspected and cleaned every 5K, then replaced every 10K. Regarding the fuel filter, if its the older plastic see-through type, then it is replaced every 20K. With the metal type fuel filters of newer cars, it is replaced every 40K.
The timing belt and water pump is usually replaced every 80K under normal driving conditions. The tensioner bearing will also be replaced as well as the gaskets and rubber seals.
If the car is equipped with a timing chain, the interval for change is longer...150K. But the interval for the water pump will still be around 80K.
These are the usual recommended intervals but consult the car's user manual for accurate recommendations of preventive maintenance.
Xiaomi E-Car
