Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    May 2013
    gud pm masters of honda,,pls help me to my honda civic vtec,96 model,manual,,the problem is hard to start,and when it start,thye gas needle or rpm is unstable then it automaticaly shut off engine,,the mechanic said first is the fuel pump,,nxt is the crank sensor,,and if the two said is not done,,last option is the computer box,,how come it happen?before it happen,ill use the car well,
    my question again is,,how much is that cost if the crank sensor plus the computer box is the damage?
    any one help me pls for some use3full advbise
    thank you very much!!!
    have it scanned first to get the actual na sira.
    mahirap manghula, malaki laki gagastusin mo eh.
    Dec 2009
    bro, nag off ba engine pag ni on mo a/c? in case yes try mo palinis yung servo mo. also baka sobra dumi na ng air filter mo have it replaced for starters.
    May 2013
    sir kahit po patay no buhay ang a/c nag off sya lalo na po pag pigain ko gas,tatas ang rpm then derocho off sya,,sabi ng mekaniko ay crank sensor daw.
    May 2013
    Quote Originally Posted by 1D4LV View Post
    sir meron ba machine na pangtest or scan ng unit kung ano talaga ang sira nito?sabi kc ng mekaniko ay crank sensor daw,,mga nsa magkano po kaya ang palitan nun?di na po ba narerepair yun?
    May 2013
    up up ko lang po,,gusto ko po kc makabisado ang car na ito,,2 yrs ko palng po ito gamit at ngayun bigla nalang nag kaganito,,
    sana po ay matulungan nyo ako,,
    Quote Originally Posted by sedemocin View Post
    ang problem kasi is hindi sure kung ano talaga ang sira eh.
    pano kung nagpalit ka na ng fuel pump at hindi pa din nasosolve ang problem? so papalit ka naman ng crank sensor..... eh pano kung di dun? pano kung electrical-related pala?
    so appropriate action is to have it scanned muna.
    depending on your location, madaming nag eengine scan. much better if you can provide your actual location para may ma refer kami na service provider nun.
    May 2013
    dito po ako sir sa bocaue bulacan,,baka po meron kayo mairerefer na mag engine scan,,any way sir,maraming salamat po,,marami ako natutunan
    Feb 2009
    check the basic stuff first. diagnosis first before repairs. do not guess. digitize your tests (meaning: put numbers into all your tests). check engine vacuum. check compression, check fuel pump pressure and fuel volume past the fuel filter. check the exhaust for restriction. if the crank sensor was bad, the engine won't even start. if the pcm was bad, the engine will not start.mechanic A says the computer is bad, mechanic B says the crank sensor is bad. who is right?
    A. A only
    B. B only
    C. Both A and B
    D. Neither A nor B.
    you be the judge.
    find a competent technician and obtain his/her numerical findings using gauges and instruments not "scientific wild ass guesses" or hula. unless he/she is hawaiian, he/she will do the hula:jeanie:
    kung merong servitek dyan, try mo magtanong if they do engine scans.
    cost is around 800 pesos, but it will save you a lot of money than having to go the shotgun route.
    May 2013
    kwento ko lang po ang nangyare bago masira car ko,,unang naramdaman ko po ito nung nagpa carwash ako at nakita ko na inispreyan ng tubig nung car wash boy yung loob ng makina itinaas po nya yung hood at inispreyan nya ng tubig,,nangyare po ito mga 4 months na,pagkatapus po macarwash ay nag start naman,,so drive na po ako,,at di pa ako nakalayo ay namamatay na ung makina,,at di mag stable ang rpm,,hinayaan ko lang po sa garahe ng ganu,at naisip ko ay baka nabasa lang,so mga ilang oras po ay ginamit ko na at nag ok naman,,sa loob ng 4 months na yun ay nagamit ko sya ng maayus at wala ako naramdaman na kakaiba sa car ko,,nito lang pong ginamit ko sya mga 30 km ang tinakbo ay bigala nalang tumirik habang trafic,,start ko andar saglit tapus mamatay sya,,start ulit at mamatay ulit lalo na pag piga ko ng gas,tataas ang rpm at bigla babagsak at patay n,,habang nasa kalsada kami dahil tumirik nga ay check ko yung tubig ay konti nalang,inisip ko baka nag overheat,kaya lagyan ko ng tubig,try ko start nag start tapus mamatay din,,kaya kaka start ko ay nag lowbat na,,kaya tawag na ako ng mekaniko,,at nung dumating ay sinubukan agad nila na lagyan ng ibang batery at yun nag star naman,at naiuwi ko pa sa bahay,kinabukasan ay ginamit ko ulit at tumakbo sya mga 30km din, at ok naman,,garahe ulit,at mga after 3 day ay ginamit ko ulit,,at yun na naman,bigla nanaman namatay habang nag papark ako sa parking,ganun nananaman ang sistema,andar saglit then off,,start ulit,piga ng gas at direcho patay,hangang sa di na magstart,
    maraming salamat po sa lahat ng tumutulong sa akin
    May 2013
    alam ko lang dito sir yokohama service center,pwede kaya dun?
    may check engine ba bago mamatay makina? parang sensor. alam ko obd 1 pa rin yung civic 96. Kung wala nagscan diyan pwede diy yan sir.
    Mar 2013
    Try mo dalhin sa Honda guiguinto kung wala kang makita, provided kung mapapatakbo mo hanggang dun.
    boss,
    i have that same problem although AT ako and same model.
    most likely you need to clean the IACV/SERVO o kung ano mantawag dun. if hindi kinaya, one thing is for sure go to the nearest surplus shop and gave your IACV sensor replaced. the problem with erratic idling is it really damaged the ecu.
    bili ko 4 years ago ng surplus na ecu nasa 4k at evangelista. yung iacv sensor 3 yun kung hindi ako nagkakamali, trial and error.
    if you want mag DIY try to log on sa hondaclub.com.ph, although di ko alam kung bukas pa sila, nakalagay dun manual ng ek at how to read the signal sa dashboard.
    May 2013
    maraming salamat po sa inyong lahat na tumutulong sa kagaya ko na baguhan,,medyo nalilinawan na ako ngayun,,try muna namin magpalit ng crank sensor,,sabi nung mekaniko ko ay 3,500 daw un,,pag nag ok na dun ay ok na,,sana ay mag ok na dun,,natatakot kasi ako sa mga nadidinig ko,sabi 25k daw ang computer box
    eh pano kung hindi crank sensor ang sira?
    May 2013
    yung nga po ang inaalala ko,pwede po kaya yun ibalik pag di naman iyun ang sira?
    yun nga yun eh.... so need mo talaga ipa scan muna..... para di sayang pera.
    most probably, hindi mo na pwede ibalik yung pyesa.
    May 2013
    ang problema po kc ay hinila lang namin ung kotse dun sa mekaniko,,parang nakakhiya namn po pag iaalis ko pa sa kanya,,pero subukan ko parin po,,,maraming salamat po,,post ko po kung ano nangyare tomorow
honda civic/vti 96,manual,auto off engine,its fuel pump or computer box?help
