Results 1 to 10 of 10
    Hi,
    I have a Honda Accord 97 and the Automatic transmission no longer shifts smoothly. From 1st gear to 2nd gear ang lakas ng kadyot pag nag shift. Same with 2nd to 3rd and 3rd to 4th, pero mas mahina na yung kadyot. Ok din naman yung ATF levels... yun nga lang hindi pa ako nag papalit ng ATF since January 2010.
    Before I bring it to a mechanic, do you guys have any ideas on what could be wrong?
    Thanks!
    Jun 2004
    how long have you had the vehicle? any history of being flooded?
    what brand of atf did you use?
    Magpalit ka na ng ATF fluid mawawala problema . Makikita mo naman sa kulay ng ATF fluid mo kung brown na ang kulay karamihan pula ang kulay pag sariwa pa ang ATF fluid mo. Sa shell service station mo na lang paggawa para malinis tuloy filter ng transmission mo.
    no history of being flooded as far as i know. try ko mag palit mamaya sa shell.
    balitaan ko kayo. Thanks!
    Malakas din yung nginig nya pag naka engage (1,2,D3,D4,R) at naka idle lang, pag naka Neutral wala naman nginig ... ATF lang din kaya katapat nun?
    Jun 2004
    yung vibration more of sa engine supports, i would suggest honda ATF gamitin mo... mas mahal lang nga un
Honda Accord 97 A/T help
