Page 1 of 2 12 LastLast
Results 1 to 20 of 41
    May 2018
    Hi hello newbie here, asak ko lng po kung meron keo idea mgkano palinis ng car aircon? at dpt ba tlgng palitan ang freon?
    Oct 2009
    Quote Originally Posted by Dancivic View Post
    ano po ba ung car ninyo.sa car po kasi binababa ung mga evaporator para malinis po..at syempre po pag binaklas pinasisingaw po talaga ung freon at pag ibinalik na ung mga evaporator na nalinis ay nilalagyan po ng bagong freon..
    May 2018
    Quote Originally Posted by jaypee10 View Post
    honda civic dimension po 2002 model. . .magkano po kya budget sa palinis po? ska mgkno po freion?
    Feb 2009
    Your car should already be equipped with cabin filter. If so, avoid the removal of the dash just to clean the evaporator.
    The evaporator should be fine. If you choose to disturb it, noises, missing parts, stripped threads go with it.
    May 2018
    then how much is the cost price for aircon cleaning? for honda civic
    Jan 2016
    About 6k siguro yan sa Denso, bilhan mo na din ng cabin filter...
    2k+ lang siguro yan. Basta walang papalitan parts.
    Jan 2009
    The Civic's evaporator doesn't require full removal of the dashboard. If I remember correctly, they just removed the blower and bits of plastic ducting to get to the evaporator. This is the Civic FD, which has very similar A/C design to the 7th Gen.
    I've had good luck with Frigid Zone along Mindanao Ave., QC.
    I suggest you calling them up or dropping by for an estimate.
    Jan 2016
    sa 2002 civic, walang baklas dashboard...
    May 2018
    okay thanks
    Jan 2009
    I don’t know... for a 16 y/o car? In my experience, a car that old, cabin filter or not, marumi na evaporator coils nyan.
    If you have a USB borescope, you can inspect the evaporator’s actual condition. At most, you just need to remove the blower for access.
    Kung wala naman sira huwag ka na pa cleaning, palitan mo na lang cabin filter.
    i second the motion.
    and i go one further. i see if i can launder the filter, instead of purchasing a new one.
    Mura lang cabin filter kaya palit na lang ng bago. Saka It's made of paper so not intended to be washed.
    i did not believe the manufacturer. i wash mine. there is no discernible ill-effect.
    sayang rin pera.
    May 2018
    wla nmn cia sira bumubuga nmn ng malamig na hangin, pro di na gnun kalamig kya tingin ko dpt ng malinisan. . . sbi kc ng ggwa ibaba ang evaporator tpos mgbabaklas cla at pplitan din ung freon. .
    estimated nia 3500 ung cleaning ung freon is 1200 plus cabin filter 600 depende pa yan kng wla clang mktang pplitan. i dont know if it is justifiable price.
    Mar 2016
    1,500 lang po pacleaning ko kasama na freon don honda civic old model din.. depende kng may papalitan pa. along commonwealth harap ng sandigan bayan.. Gerry's Aircon ang pangalan don din ako nagpagawa ng aircon ko..
    Mar 2004
    Quote Originally Posted by mjamolin24 View Post
    1500-1800 is too cheap for decent aircon cleaning service ... Refrigerant cost alone is already 1,000+ ... Maybe they are recycling refrigerant ... It's not advisable ...
    Mar 2016
    ganun po ba?. pero mag 2 years na po malamig pa nman po..
    Dec 2025
    Hi there! Welcome to the community. 😊 For a Honda Civic 2002, cleaning the car aircon usually involves a thorough chemical wash, especially if you notice reduced cooling or odor. When the evaporator is cleaned, the freon (refrigerant) is often replaced to ensure the system works efficiently.
    In Singapore, professional services like Aircon Servicing handle both cleaning and refilling safely, preventing leaks and restoring performance. For example, a friend had his Civic aircon cleaned here, and after the chemical wash and freon top-up, the cooling became noticeably stronger and the air fresher.
    You can check detailed service options and pricing by click here. It’s often more cost-effective than DIY and guarantees proper handling of the freon.
car aircon cleaning
