Results 1 to 11 of 11
    Jul 2010
    [IMG]file:///C:/Users/RGL%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/RGL%7E1/AppData/Local/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/Users/RGL%7E1/AppData/Local/Temp/moz-screenshot-2.png[/IMG]
    Guys, where could this oil leak possibly coming from? anyone here experienced the same problem with mine?
    I've already replaced the following gaskets and oil seals: ,
    VALVE COVER GASKET
    OIL SEAL DRIVESHAFT LH
    SHIFTING ROD OIL SEAL
    CRANKSHAFT OIL SEAL
    OIL PAN GASKET
    am i missing out something? i really need your inputs. thanks in advance.
    Aug 2007
    Quote Originally Posted by RG-93 View Post
    VALVE COVER GASKET
    CRANKSHAFT OIL SEAL
    OIL PAN GASKET
    chief we have a the same problem. is your oil seals crank & cam shaft is HONDA GENUINE..? if not yun ang problema.. iv bought a replacement parts they say its Japan made but the problem is..hindi talaga sila TUGMA sa sukat even doe they've been measured by some autoshop.. twice na ako nagpalit ng oil seal when my mechanic saw my oil seal are replacement.. he totally told me that bumili ako ng Genuine parts HONDA mismo.. to tell you honestly pricey siya talaga ng 150php.. replacement parts kasi nasa 130php so dapat dalawa 260php i bought it sa FERTES. but from HONDA SPA i bought it by 250+ so dalawa mga 500-515php lahat.
    Kung ako sayo buy a genuin parts sa HONDA mismo, ganun din ang suma kung papalit-palit ka ng oil seal.
    cam shaft?
    ive been using replacement seals for a long time and it never gave me problems. the best is take out the cover sa timing belt then see if the leak is coming from there.
    lakas ba tagas ng engine? how many times do your refill oil? palinis mo muna yung mga oil tagas kasi its much easier to track down a leak with a clean engine.
    edit: matic o manual?
    Aug 2007
    Quote Originally Posted by archie123456789 View Post
    cam shaft?
    *archie123456789 chief ano auto mo.? at saan ka nakabili replacement parts for honda?
    Quote Originally Posted by Hondabot View Post
    sa car power sa pasay or HRC sa banawe.
    ek civic LXi 2000 m/t.
    Jul 2010
    Yes sir Hondabot, genuine yun parts na naikabit dahil sa CASA ko sya pinagawa, nadala na ko sa replacement nadoble gastos ako sa parts and labor hindi nagfit yun nakabit ko dati kaya pag Oil seals and Gaskets sa casa ako bumibili and nagpapagawa para sigurado pero hindi lahat ng gawa nila pulido,last time nagpagawa ako nakalimutan nila higpitan ang Top engine support ko kaya makalampag,pinababalik ako pero kami nalang naghigpit kaysa babalik pa ako sa casa malayo sa bahay sayang ang gas. nasigawan ko tuloy yung SA nila hehe
    Anyway it might be the cam shaft, i can't remember replacing it yet. sana tama si sir archie123456789. M/T yun EK ko sir. Already had an under car wash pero meron pa din yun leak. Patak patak lang naman siya. Thanks for your inputs mga sirs.
Oil leak civic ek need help
