Results 321 to 330 of 645
November 8th, 2009 06:45 PM #321
how do i know if the honda accord '96 with h22 that i got is a dx, ex, or lx? and another one - i had my headlight assy changed because the old ones were yellowed with age. i got a set of stanleys together with the signal light housings - my question is - what accord model had h1 and h4 bulbs factory-installed with it; and the the signal housing also has only 1 socket so now its only my park light and my bumper lights as signal.
November 8th, 2009 07:29 PM #322
out of the topic though, i've seen a maybe 94 model or so accord with a carbon fiber body as in the whole body is carbon. it shocked me of knowing how much would you spend on having the body to be carboned.
November 9th, 2009 11:49 AM #323
- Aug 2009
- 56
November 10th, 2009 03:20 PM #324Good day mga sir update lang po nakapag palit na ako ng timing belt complete set sya timing belt,balancer belt,water pump,bearing at mga oil seal ok na ngayon accrod ko sa partstar sa pasay ako bumili ng pyesa p6800 lahat at 1800 ang labor,
- Aug 2009
- 14
November 15th, 2009 03:26 AM #325Originally Posted by Aponizuma
thank you very much for the tip sir. it has around 160K on it before the speedo crashed so i guess its in the 180K range now. they say that timing belt replacement is better done with water pump changing to save on labor - is the water pump reservoir the same thing that i used to fill up for my window washers? i don't see any leaks but the water does go down everyday i check it. please advise. i will definitely do the compression test and have my pumps and filters checked on too.
try mo palitan radiator cap..baka sira na..ngyari n kasi sakin dati..nagbabawas ung coolant..when i had it replaced ok na.
November 17th, 2009 12:55 AM #326
November 19th, 2009 11:11 AM #327
Just got our 96 Exi Accord around a month ago. Meron lang ako mga ibang tanong.
Matigas ba talaga clutch nito? Compared sa ibang M/T vehicles na nagamit ko parang matigas itong Accord.
Second question, san niyo marecomend ang mga shops or mechanics na magaling tumingin at gumawa ng [H]? At any recommended shops for [H] parts?
Thanks.
November 23rd, 2009 05:52 PM #328
- Dec 2008
- 50
November 24th, 2009 09:14 AM #329
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
