Results 1 to 5 of 5
- Sep 2015
- 37
July 8th, 2019 01:55 PM #11) Procedure: DIY replacement of burnt-out bulb of aircon button (beside the rear window heater button).
2) Part No. or specs of replacement bulb.
Will appreciate any info.
Sent from my GT-I9505 using Tapatalk
- Sep 2015
- 37
July 27th, 2019 10:06 PM #3
- Jul 2009
- 2,618
June 13th, 2020 11:37 PM #4just in case may interesado pa. just replaced a cousins A/C button light. 2009 Jazz 1.5 GD but it will probably be the same o similar sa ge.
all you need is a phillips screw, a small pry bar para lang mapindot yun tab ng button ma release sya.
removing the a/c panel is just two screws the rest are just clips.
bulbs are two (2) pieces of T3 neo wedge also called twist lock ata. that's it.
after two years at maling nabiling bulb (dilaw na masyadong malaki is a t4.2) napalitan din yun bulb hehe.
- Sep 2015
- 37
July 30th, 2020 12:48 PM #5
