Results 1 to 17 of 17
    I recently bought a 2nd hand city 2010 a/t model. Just want to ask what are the cause of the hot wire in the battery, Ayaw mag start kanina ng auto ko. Last weekend nadehydrate yun battery nya so dinala ko sa motolite and nilagyan nya ng battery fluid and chinarge. Tapos umandar na nung naayos. And then when I start my car this morning ayaw ulit umandar and pagpunta ko sa hood mainit yun ground wire. Please help me on this. thanks
    Quote Originally Posted by goldwin_1110 View Post
    It looks like loose ground wire bro... Check if the connection is tight between the battery terminal and the body of the car... Isang wire lang naman iyan, di ba?
    18.9K:smooch:
    Jul 2011
    18.9K:smooch:
    any ideas bakit uminit ung ground wire kahit loose connection?
    yes bro, negative wire lang sya. So it does not affect the whole electrical wiring of the car?
    Jul 2011
    sir baka meron kang short, check mo other parts ng car mo na umiinit.
    kung wala kang short, baka kaya umiinit ung ground mo e marami kang electronic gadgets (loaded na ung wire), try mo magdagdag ng grounding cable from battery to other parts of your car with negative connection.
    Quote Originally Posted by Manilablock View Post
    wala naman gaano gadget yon. meron lang sya lcd audio and security alarm. okay hanap ako magaling na auto electrician.
    It will bro.
    The reason I was saying that it is "only one wire", is because the (negative) battery terminal is directly wired/connected to the body of the car, as in the case of the City.....
    18.9K:smooch:
    Oct 2011
    Sir, make sure it is tight and grounded sa body ng car ung negative terminal and have a qualified car electrician to check kung may short or grounded may standard test yan na ginagawa malalaman na agad.
    It will bro.
    18.9K:smooch:
    Dalikado ba sya kung itakbo kung ipapaseries ko. Kasi kelangan ko sya dalin sa casa for checking and maintenance. sorry first time car owner kasi. thanks for the reply
    Is it very hot?
    If not (just warm to the touch), just check if
    1. the connector to the battery terminal and (I assume that the connection is clean)
    2. the connector to the body of the car
    are tight...
    Then drive it to the nearest shop for checkout...
    No need to alter the setup, bro.
    18.9K:smooch:
Battery negative terminal (HOT)
