Results 1 to 5 of 5
    [SIZE=2]Hello, guys. I really need some help. I have a 1996 Honda Civic LXi AT. Ang problema [/SIZE]pag nilagay ko sya sa D4 ayaw mag-engage ng transmission, ayaw umandar. Pero if I shift it to 2, it will engage and run and drive like I'm using a manual transmission. Ano kaya problema? Help, please.
    Nov 2007
    sir natry mo na ba magpalit ng ATF?
    Aug 2004
    If it's only in the D4 position that it doesn't run, then it's probably a problem with the shifter itself, and not internal to the transmission.
    Apr 2004
    start with the cheapest option... replace ATF. if that doesn't cure it, have it looked at ASAP.
    worst case scenario overhaul or palit surplus. mura lang yan, around 6-8K (daw).
    Minsan lang ito nangyari sa 99crv automatic tramission ko doon sa gauge nag blink-blink D4. then i use to turn off the engine and turn on the engine again hindi na nagblink ang green light sa D4.
Automatic transmission problem
