help naman sa aking 2007 honda civic.
automatic transmission ko hindi ko maayos. ang shifter button hindi mapress.bakit kaya? nasa P sya ayaw pumunta sa drive kasi nga hindi mapress ang button, parang nakalock sya. ano kaya problema neto??
sir,
check mo yun brake pedal sa ilalim. meron yun 2 switches. isa para sa brake lights, at yun isa ay switch para ma-unlock from park to reverse.
baka sira na yun sensor nito, kaya ayaw mag release yun lock.
Check if the brake lights still works when you step on the brake pedal. If it's not, the brake light switch is defective. The same switch also operates the transmission interlock.
There was a recall of the same switch a couple of years ago. It seems that excess lubrication from the steering column found its way into the switch which causes it to malfunction. If your FD is still under warranty, just bring it in and it should be replaced for free.
To temporarily release the transmission interlock, there's a small slot in front of the shift lever. You need to remove the small cover and insert a key or screwdriver to release the shift lever from Park.
hi,
resurrecting this thread. kasi i have the exact same problem w/ my FD civic wherein hindi kumakagat into gear from P. i also notice that the brake light doesn't work when depressed. if i have this serviced, malaking problem ba ito? i mean kaya bang gawin in one day? kasi i plan to use this sa holy week to travel.
thanks, guys.
