Results 1 to 14 of 14
    May 2018
    Mga boss ask ko lng my battery naman yong ssakyan bakit di po ngsstart ano po ang problema?matagal po nanastock?
    Quote Originally Posted by Dancivic View Post
    dagdagan nyo po ng detalye.
    napakaraming posibilidad kasi.
    ano ang sasakyan?
    gaano na katagal naka-tengga?
    kunektado ba baterya? (you'll be surprised...)
    may starter ba? (heh heh).
    gumagana ba ang starter, o "klik" lang ang naririnig
    rumeredondo ba, nguni at hindi tumutuloy? may mga ilaw (headlights) na malakas naman? gumagana ba ang busina?
    may gas ba? may na-amoy ba kayong gas?
    Sep 2006
    When you turn the ignition key, do you hear the starter cranking sound or do you just hear a click?
    May 2018
    ano ang sasakyan?
    Honda civic dimension 2002 po. . My ilaw ung speedometer gumgana stereo po. . Kapag start cia nwawala ilaw pro prng wlng pmapsok na kuryente sa starter po kpg inistart? Wla nmn pong amoy gas!.
    Mar 2018
    Most probably diskargado baterya. Kahit may ilaw speedometer and may radyo di ibig sabihin okay battery. Baka wala na din gasolina.
    Sent from my ONEPLUS A3003 using Tapatalk
    Sep 2006
    ano ang sasakyan?
    Haha. Inulit ko lang pala couple of questions ni doc haha
    May 2018
    Quote Originally Posted by RavenBlack View Post
    Sinubukan ko ng nirecharge battery sna umandar. . Sa gasolina nmn kalahti pa meron cia. . .bka mhna battery 6.5 meron cia nubg sinaksak ko ung charger
    Mar 2018
    At 6.5 v totally wala na charge. Should be 12.6v kung off anf makina. Even at 12v almost paubos na charge ng battery. You can also use jumper cables to start your engine.
    i agree with raven.
    your battery is very sick, sir.
    try to see if charging it can revive it.
    if your car is MT, you might be able to push-start it. then you can drive to your battery store for a new battery.
    if AT, try jump-starting it. if successful, drive to the battery store.
    good luck.
    May 2018
    i agree with raven.
    good luck.
    it is okay now sir. i have revive the battery thru recharging. . . i thought there was something that's why the engine was not starting. . .
    hah hah!!
    may natutunan tayo today: "all is not lost, even if it looks that way... at first."
    errr... ilang buwan po naka-tengga yung sasakyan?
    May 2018
    hah hah!!
    2 weeks lang po na istock, ngyon po okay na tumatakbo na ulit. . narecharge lang ung battery. . nadiskarga cgro ung battery tagal kasi di nagamit!. . .
    di naman ganun katagal ang 2 weeks bro.
    pacheck mo nadin electrical, baka may
    2 weeks?
    our cars start with one easy click, even after more than 4 weeks of non-use. both diesel and gas.
    as ninja says, have you car checked.
Ano po problema bakit di ngsstart?
