Di ko naisip yun a. Pero... Nice idea pala na walang drl
Check here...
Tyre reviews, tests and ratings - Tyre Reviews
Adjusted my headlight para tumaas aim, mas comfy na mag drive pag gabi lalo na at high speeds.
Doesn't look like may auto-levelling, mukang na false-advertisement tayo.
Paano na ngayon yan pag fully loaded ka na? Di kaya mas matindi pa yung glare sa oncoming vehicles?
Ako naman hindi ko napapansin na tumataas yung aim ng lights even if I have two adults at the back plus their luggage in the trunk.
But you may be on to something as I cannot also seem to find any leveling mechanism around the headlights. Maybe it's inside the housing?
Totaled Civic FC doing rounds on fb... Gearbox replacement then alleged loss of brakes which caused SUA???
Doesn’t add up though plus the driver was apparently up there in age?
normally when the steering gear box is replaced, the wheel, brake caliper, and knuckle are removed, then subframe has to be lowered then they replace the gear box or steering assembly.
the brake lines can hold the caliper if its still new. even if the tech was lazy.
also if the brake fluid was low before the accident that would have been recorded in the error log.
after the mechanical job is done, the steering angle sensor have to be programmed afterwards.
brake system wouldn't have been compromised by this recall job.
Mine I think has a brake booster/vacuum leak.
Everytime I start the car in the morning, the brake pedal is hard to press.
This has been going on since I got the car, turning 1 year old next month already.
May recall na sa US for EPS. Sa pinas kaya kelan? Saka sana sama nila 2016 models.
Mga bossing magandang umaga po. Anybody here knows if there is an OTA Update for our Head Units? My phone was updated to Android 9 and when I connect it to the car, Android Auto says that it's not compatible due to some sort of security issue. Salamat po.
