Results 1 to 4 of 4
    Hi! recently change my transmission to a japan surplus cvt
    1st problem (changed orig due to grinding/tunog bakal na gumagasgas on acceleration from full stop, pero nawawala after)
    2nd problem yung japan tranny naman till 4th gear lang. ayaw na magshift need pa naka cvt mode para magshift to 7th.
    baka meron diyan mga nakaexperience ng same problem. help naman. thanks!
    2005 gd 1.5L vtec 50km palang mileage 1st owner din.
    Sir di kaya po sira yung surplus tranny mo? dba pag bolt on dapat maayos naman yan? thought dont know anything bout cvt tranny
    yun nga din ang naisip ko, need ko daw lagi naka cvt mode para magshift til 7th.. hassle sobra. and parang naka overdrive naman ako lagi sayang gas...
    Feb 2009
    Hi,
    My brother’s CVT tranny also experienced the same problem after getting his tranny replaced with Japan Surplus. Gear shifting is stuck at 3rd/4th gear unless 7speed mode is activated (either manual or auto).
    My mechanic says it’s because it came from a right-hand-drive. Is there any workaround or additional work that needs to be done as a rule of thumb when getting Japan Surplus Trannies?
    To the TS, I know this is an old thread but was your problem solved?
    Thanks in advace for those who will reply
surplus japan cvt transmission problems
