Results 1 to 3 of 3
- Nov 2010
- 1
November 13th, 2010 02:24 PM #1hi mga sirs,
ask ko po kung saan pwede mag paayos ng honda odyssey (95 model JDM)
problem ko po ay tungkol sa idling, mejo malakas ang engine vibrations pag naka idle lang, gaya pag nasa trapik ka nakahinto.
pina tune-up ko na lahat, pina adjust yung idling speed valve.. pati engine support napalitan na din..
what seems to be the cause? diko na alam anu pa pwede cause neto.
saan po magaling na shop pwede pagawa ito.
thank you very much..
- Nov 2010
- 22
November 27th, 2010 12:49 PM #2
- Nov 2009
- 456
November 27th, 2010 06:14 PM #3As previously suggested, have the idle air control valve cleaned. Check din kung yung rubber seal nya ay buo pa, baka tumatagas dun ang hangin kaya hindi maganda idling.
Clean the air filter element, replace kung maitim na masyado. Since 15 years old na ang kotse, check din yung spark plugs, high tension wires at ignition coil.
Check din ang electrical system, specifically the alternator.
Double check all engine and transmission mounts, baka may isa dun na biyak na ang goma, pwede yun magcontribute ng excessive vibration.
Monk-owned R53
