Page 80 of 137 FirstFirst ... 307076777879808182838490130 ... LastLast
Results 1,581 to 1,600 of 5300
    Nov 2017
    Ilang araw po bago nyo nakuha ung OC/CR sa dealer?
    Quote Originally Posted by fflip3r08 View Post
    Released after 3 weeks. Honda Carmona.
    Yup! Correct!
    For diesel owners who had the 16wt oil during PMS, how do you find it?
    The thin oil seems to have made the engine a bit more clattery. The factory fill seems better.
    Acea c3 siguro Yun factory fill
    Dec 2017
    A more viscous fluid should theoretically have greater internal damping. Thereby making it quieter.
    Quote Originally Posted by drew_cc View Post
    Yeah I think the factory fill is thicker. 20wt or 30wt maybe.
    Is there a 30w diesel oil from Honda ph?
    Sep 2014
    Just had my 10k pms and this is what I noticed. Not a fan of the oil casa used.
    Nov 2017
    Normal po ba ito sa experience nyo? Kakakuha ko palang sa casa. May water moisture agad sa headlight, umuulan pa naman ngayon
    Apr 2014
    This doesn't look normal bro. Best if you report to casa ASAP para maagapan.
    Nope, that is not normal. Dapat sealed yang headlight eh.
    Nov 2017
    Salamat sa payo mga sir
    Oct 2003
    CMIIW I think naka state ata sa manual na a little moisture is normal due to rapid change of temperature. As long as mawala din siya after a while i think you are okay. Ibang usapan na pag naging aquarium na ung headlights of course.
    Quote Originally Posted by zechs View Post
    If wh1st3er's crv headlights are dry, would the foggy headlight still be normal?
    Nov 2017
    Do you still warm up your diesel engines the usual way of leaving it idle for quite a while?
    Apr 2014
    Nope but I do cool it down before turning it off. I avoid doing high revs when Im near my house
    Aug 2017
    90 sec is more than enough to warm up. Doing this from going out of the garage stepping on break pedal only.
    Sent from my iPhone X using Tapatalk
    I heard that somewhere they are selling kits for the auto open/close of the tailgate. Any idea where and how much?
    Sep 2017
    Quote Originally Posted by Mguy View Post
    meron ako nakita sa FB pero nag alangan ako dahil komo mechanical yan so im not sure kung ano klaseng warranty bigay nila kung magloko. di katulad ng sa store eh may competent na tao na gagawa kahit paano.
2017 Honda CR-V Turbo and 7seats
