Page 79 of 137 FirstFirst ... 296975767778798081828389129 ... LastLast
Results 1,561 to 1,580 of 5300
    Oct 2017
    Karamihan kasi hindi ginagamit ang max blower setting. Use max without compressor. This will somewhat help...
    Tried this kanina bro somehow nabawasan yung amoy pag on ng ac. Will chek again tomorrow if it's totally gone. Thanks.
    Better ang 0w-30. Mainit sa atin.
    The Honda Diesel Oil #2.0 is a 0W16 viscosity.
    Quote Originally Posted by gls2001 View Post
    Philippine market?
    Philippine market?
    Yes. Bought a liter at Honda Carmona.
    Lemme guess its 899 pesos?
    Sep 2018
    Quote Originally Posted by istan View Post
    The Skinny on OW-16 Oil - National Oil & Lube News
    "0W-16 oil was introduced in Japan before 2000. 0W-16 showed higher fuel economy than 0W-20 engine oil. It will also give you remarkable quick engine starts at cold temperatures. There are several concerns [about 0W-16 oils] due to their lower viscosity, like increased wear, increased oil consumption and lower oil pressure. But our long history [with 0W-16] has addressed these concerns. The 0W- 16 project is just the beginning of what JXTG Nippon Oil is striving to do to offset carbon footprints. Actually, we are currently working on an 0W-8 oil."
    Quote Originally Posted by tsk_001 View Post
    "who is 'we' ?"
    "who is 'we' ?"
    Eneos Oil Rep . Miyam Oto and TakaHa shi
    Sep 2018
    NOLN: What are some of the changes manufacturers will make in engines as we start to move into these lower viscosities?
    Miyamoto: It depends on the company, but we need to control some factors like pressure and friction conditions.
    Considering Honda was able to reduce the mechanical friction of the 1.6-liter i-DTEC engine to the level equivalent of a petrol engine:
    “All the rotating parts have been carefully optimized to reduce their friction,” says Tetsuya Miyake. For example, a shorter and thinner piston skirt has been used. At 1500 rpm, the 1.6-liter i-DTEC has around 40% less mechanical friction than the 2.2-liter i-DTEC. This not only reduces emissions and improves fuel efficiency; it also improves the engine’s response, both on and off the throttle, making the car more fun to drive. We have reduced the mechanical friction of the engine to the level equivalent of an existing petrol engine, which is an outstanding achievement.”
    0W-16 does actually make sense. It's all about fuel economy & efficiency, folks. Earth Dreams?
    Sep 2018
    0W-16 does actually make sense considering Honda was able to reduce the mechanical friction of the 1.6-liter i-DTEC engine to the level equivalent of a petrol engine. “All the rotating parts have been carefully optimized to reduce their friction,” says Tetsuya Miyake. For example, a shorter and thinner piston skirt has been used. At 1500 rpm, the 1.6-liter i-DTEC has around 40% less mechanical friction than the 2.2-liter i-DTEC. This not only reduces emissions and improves fuel efficiency; it also improves the engine’s response, both on and off the throttle, making the car more fun to drive. We have reduced the mechanical friction of the engine to the level equivalent of an existing petrol engine, which is an outstanding achievement.” The new 1.6L i-DTEC Honda engine
    It's all about fuel economy and efficiency, folks. Earth Dreams?
    Don't understand. Those xW-x are operating temperatures of the oil right?
    0w-16 is perfect for Japan weather.
    Its just too hot here in Manila. Will wear oil down faster. Thats just me tho.
    Anyways, following car manual should be ok.
    Viscosity * 100c doesn't mean ambient temp
    As a reference in the manual, correct me if I'm wrong but my understanding is the Honda Diesel Oil #2.0 has the same operating ambient range as the 0W30 or 5W30 ACEA C2 / C3.
    Correct bro[emoji106]
    Ahhh ok. Means Engine temp?
    Engine temp will be regulated by the cooling system regardless of the ambients
    Nov 2017
    May first 1000km PMS po ba ang CRV? Makukuha ko palang unit ko in 2 days, balak ko sana i roadtrip agad.
    Quote Originally Posted by fflip3r08 View Post
    Yes meron. Check up lang gagawin dyan, no fluid changes to be done.
    Silip lng kung meron tagas engine, tranny, brakes and cooling.
2017 Honda CR-V Turbo and 7seats
